Some guidance/help required on connecting an Autocom on a Yamaha XT1200Z
siddhartha
Post by siddhartha »
Now have Zumo 660 installed on bike - great piece of kit.
Now want to connect it up to an 'old' Autocom Pro-7-Sport.
I was able to install autocom myself on a Triumph Thunderbird by wiring it into the rear broke light connector/cable near the brake pedal - but am stumped as to how to connect it up on the Super Ten.
Have removed seats etc to check access to wiring etc - but cannot work out where to wire it in...
The Autocom guide suggests that it should be fitted by a dealer if bike is still under warranty and has ABS.
Have looked at the other threads with complex relay boxes and stuff...but suspect that may be beyond my capabilities.
Any help or instructions etc appreciated...thanks.
You never see a motorcycle outside a psychiatrist's office - unfortunately this is not my own quote.
Tenere XT1200Z / Triumph Thunderbird
Heff
Has thanked: 315 times
Been thanked: 143 times
Re: Some guidance/help required on connecting an Autocom on a Yamaha XT1200Z
Post by Heff »
I use an Pro 7 Sport on my GS1100 Panzer.
I have mine wired into thr rear light, as I always ride with my lights on therefore the Autocom is on only when the lights are on.
So never have to worry about switching it off.
I would imagine finding the wires behind the light unit should be easy enough
Heff
tiger800xc
Has thanked: 14 times
Been thanked: 3 times
Post by tiger800xc »
have you tried the eastern beaver kit?
really simple to use, as it connects directly to the battery using a inline fuse, although you will still need to wire directly into the live feed on the back light so the sat nav is always live
Failing that if you are at the boil rally ask me and i will show you the kit etc
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
Ferris Bueller
siddhartha
ok thanks - what I can't work out is where/how to get access to the right point at which to connect the autocom wire to the back light wire or what you call the 'live feed' to the back light....if that makes sense?
One connection from the auto com goes directly to the battery - I can do that ok - just need to work out where to connect the other wire...everything is sealed near the brake peddle...and I have yet to work out where to join the other wire.
gazxt1200z
Has thanked: 3 times
Been thanked: 28 times
Post by gazxt1200z »
go in the right side panel where the battery is,above it to the right you will see 2 sets of wires both sets are connected to half of a funny shaped white plug,snip one of these white plugs off[they dont marry up to anything]the 2 wires that you have left are earth and an ignition live,job done.I've used both sets on mine for spotlights and heated wraps.
siddhartha
gazxt - ok thanks - will check out tomorrow - how do I determine which is live and which is earth?
Or are they colour coded to tell which is which?
gazxt1200z
Can't remember the colours sid but if you buy a cheap electrical screwdriver with the wire coming out of it and a crocodile clip on the end put the clip on the brake pedal expose both the wires turn on the ignition touch each wire with the screwdriver,the live will light up the screwdriver OR the earth is usually the one with a bit of black running through it.
siddhartha
Excellent - thank you. Will experiment tomorrow.
siddhartha
Hello again Gazxt,
Is this the wiring/connector you are referring to?
gazxt1200z
yes mate that's one of them,there's another like that in there somewhere,sorry i've been away for the weekend.
