Greetings folks,
Just a quick mention of excellent service from two companies;
Trail & Trials Fife 01334 840414 https://www.tytrials.com
In Motion Egham 01784 440033 https://www.inmotiontrials.com
Anybody needing front fork gaiters; Ariete ART06962
Serow Parts.
Re: Serow Parts.
Many Yamaha parts are interchangeable between models but you need a part number. I generally look up the part on Fowler Yamaha, from whom I have had good service in the past, they have the parts list online, from there you can check availability and other models that use the same part. I needed front fork bushes, seals and gaiters which Fowlers listed as no longer available, I eventually got the bushes from T&T which has similar parts list online but they did not have the gaiters.
My original gaiters were made by Polisport but are no longer available so I contacted another established company and they recommended I try 'In Motion' who are trials orientated. The chap I spoke with, Robin, went and measured some gaiters and found a pair, specified for a Montessa and made by Ariete. Robin actual tried fitting them to similar sized parts and returned my call. Parts arrived by next day delivery.
Hope this helps.
Hope this helps.
catcitrus
- Has thanked: 100 times
- Been thanked: 470 times
Re: Serow Parts.
I agree on the best approach--that is to find the correct part number and search with that--so far I have found an alternator side case gasket, an O ring for the large camshaft drive sprocket cover, a sprag clutch, starter motor and a new idle mixture screw--needless to say I'm having a bit of a "Lionel" getting it sorted, but parts are out there, especially from the US where its referred to as the XT250 only, not the Serow.
