Africa Twin Adventure Sports
Tonylancs76
Been thanked: 8 times
Post by Tonylancs76 »
Evening all,
I’m ok at riding bikes but when it comes to anything technical I’m still learning and finding my way! So hopefully this isn’t a daft question
On my ATAS the battery is in the most stupid place I’ve ever seen on a bike, however I am trying to fit a battery trickle charger and also my lead for the heated gear I use in winter, but I can’t seem to get the terminal bolt back in when it’s got both leads on it.
So is it simply just to use a longer bolt or is that a no no?
Thanks
Tony
garyboy
Has thanked: 2418 times
Been thanked: 1041 times
Re: Africa Twin Adventure Sports
Post by garyboy »
Maybe jam something at the back of the little nut to bring it nearer the bolt. to start it off.
Tonylancs76
Ok thanks I’ll give that a try
Cheers :D
v8mark
Has thanked: 18 times
Been thanked: 80 times
Post by v8mark »
I have seen blue tac used to push the nuts forward and hold them there
Has thanked: 1612 times
Been thanked: 1830 times
Remember to connect the Earth ( – ) wire last
garyboy
Post by garyboy »
It's weird .. I'm sure years ago it was earth wire first .. things are not the same, half a century on lol
catcitrus
Has thanked: 100 times
Been thanked: 467 times
Post by catcitrus »
The reason that its earth wire last is that if a positive is connected to the battery and a "live" positive extra lead touches the frame then there will be a short to earth.
lancashirelad
Has thanked: 201 times
Been thanked: 273 times
Post by lancashirelad »
On one of my bikes I had to order longer bolts when I was connecting the Optimate lead, only place I could source them was China, by the time they arrived I’d sold the bike!!
Magnusson
Has thanked: 540 times
Been thanked: 234 times
Post by Magnusson »
I'd get a fuse box. Then you only have one set of connectors on the battery and the fuses more easily accessible. Some of the latest fuseboxes have outputs that you can turn on and off and fuses that you can reset all from your phone.
The main reason for connecting the negative last is if you're connecting the positive and your wrench touches the chassis nothing happens. Then when connecting the negative if your wrench touches the chassis nothing happens.
If you connect the negative first and your wrench touches the chassis nothing happens. Then when you're connecting the positive and your wrench touches the chassis you have what the professionals call a short. Worst case scenario is your bike catching fire, that spreads to your shed, and then your house, with you, your wife and kids inside. More likely nothing happens, or you only get a small black spot on your wrench. But the smart thing is to connect the negative last.
garyboy wrote: Wed Jul 06, 2022 8:14 am It's weird .. I'm sure years ago it was earth wire first .. things are not the same, half a century on lol
Earth off first, on last...isolates the spanner from being a conductor.
Bear in mind that a vented battery gives off hydrogen when charging.
