Yamaha XTZ 1200 Super Ténéré heads up for clutch casing cracks
WIBO
Has thanked: 618 times
Been thanked: 655 times
Post by WIBO »
Just a heads up in that there seems to be a few cracks on certain model years clutch casings here in France, according to the forum I post on.
Wouldn't do any harm to check if your have an XTZ or know someone who does?
Check the link and you'll see a poll where there's some showing cracks from the factory. Scroll down and you'll see some pics as to where to look.
For info.
https://www.super-tenere.org/t4551-fiss ... -embrayage
:D
Will It Buff Out?
Dark Knight
Been thanked: 99 times
Re: Yamaha XTZ 1200 Super Ténéré heads up for clutch casing cracks
Post by Dark Knight »
Checked my 2011 S10 clutch casing, no cracks visible.
Maybe caused by someone over tightening the clutch casing screws?
WIBO
Post by WIBO »
Great news along with relief.
:D
Will It Buff Out?
andyb43
Post by andyb43 »
Yep mine went noticed just outside warrant so yamaha laughed 😂 been told the steel dowels expand more than the aluminium and crack the case on some. I ended up filling the dowel hole with black sealer and sorted
scaley
Been thanked: 4 times
Post by scaley »
The early XT's had an issue with the clutch cover cracking after about 6 months. This was due to too long dowels being used , the gasket would contract with age allowing the cover to stress on the dowels. My 2010 was replaced on warranty. Usual first symptoms are oil leaks around the gasket. On no account should the screws be tightened without first shortening the dowels a few thou.
Regards
Scaley
WIBO
Post by WIBO »
I'll pass the info on to the French forum.
Thanks
:D
Will It Buff Out?
