netsonic wrote:Hi Graham, when you say your running out of fuel is that by the fuel guage or is there actually no fuel in the tank?......if its the former then its likely the sender unit needs calibrating as i did and wrote about in a previous thread. The other issue could be a vacuum in the tank, puts the fuel pump under load and reduces fuel into the injecter. Try taking the brown fuel cap gasket out of the filler cap which lets the tank breath better....mind out for the small parts in the cap if you do this
I ran out of fuel out in the sticks when I got picked up and when to the fuel station I could only get 12.5 ltrs in the bike, there was a small amount of fuel left in the tank when I looked, no where near 6 ltrs that I thought should be in,
Today it ran much better on the trails, I left the fuel pump to prime when I turned the key, it didn't stall once but maybe twice struggled to start a bit,
There's loads of dust when riding will this not get into the tank if I remove the gasket
