BMW R1200 GS Adventure tyre valve gizmo
Road2Manchester
Post by Road2Manchester »
On my Adventure I am always having issues with pumping tyres up. With wire wheel spokes just about in the way, its virtually impossible to use a standard petrol station |Pay as You go air inflator. Even the PCL double outlet ones will not go on, especially the rear wheel, there just ain't enough room.
SO I bought one of those 90 degree adapters to screw on each time....... it doesn't screw down far enough, so the air escapes around it..... so I went to Halfords and bought a rubber hose with a fold down connector, cut the end off the 90 degree thingy, and made this, much easier, and works a treat.
hope this helps... total cost was about £12.
cam to gif
If you ride like the wind, expect to get blown away. One lifetime is all we get use it wisely this ain;t no practise.
Treadtrader
Moderator
Has thanked: 27 times
Been thanked: 74 times
Re: BMW R1200 GS Adventure tyre valve gizmo
Post by Treadtrader »
Tidy solution to the problem mate.
Moved to the "How to " section, there's prizes. ;)
Adrian
Been thanked: 5 times
Post by Adrian »
That's a great idea. I have had this problem
Steve T
Has thanked: 260 times
Been thanked: 841 times
Post by Steve T »
Very neat solution - well done.
Me, I always check my tyre pressures before I leave home using a pencil type pressure gauge, using a footpump if more pressure is required. When away from home I carry said pressure gauge and if required I add pressure using a mini compressor.
Just my ramblings
Steve T
B)
ZEN DOG
Return to “HOW TO..........”
