Drawing on and Embedding a Map - technical help please
Help, rules, advice and announcements.
Barcelona Pat
Has thanked: 411 times
Been thanked: 93 times
Post by Barcelona Pat »
Hi all. I´d like to put together a map of the Americas on which I could plot my planned route next year, and then publish it on my blog. I´d also then like to be able to draw my actual route on the same map (in a different colour) and update it from time to time as a record of the trip. Any ideas all you clever IT types? Any help or signposting received with mucho thanks. :)
B)
Pat
knobblywobbly
Been thanked: 5 times
Re: Drawing on and Embedding a Map - technical help please
Post by knobblywobbly »
Googlemaps should enable you to do that with a little bit of fiddling.
Morph
Has thanked: 207 times
Been thanked: 92 times
Post by Morph »
I created this map at;
http://www.travellerspoint.com/travel-maps.cfm
But there must be better sites.
2 months_2011-10-11.jpg (241.41 KiB) Viewed 1635 times
This site looks quite good;
http://www.mytripjournal.com/
stormfield
Post by stormfield »
Googlemap guide here:
http://maps.google.com/support/bin/stat ... 21676&rd=2
You can drop different icons e.g. campsites, ship ports, sightseeing places.
You can also draw lines on the map.
scouse
Has thanked: 10 times
Been thanked: 7 times
Post by scouse »
Try using Google Earth... and create a kml file which can be put up on a website to open... Actually I'll get back to you on this one as I am looking at a couple of ways of doing this myself.
susurro
Post by susurro »
Thanks Barca Pat - this is a really useful thread all of you :D
Road2Manchester
Post by Road2Manchester »
I treid googlr maps 30 times prior to my us tripand every time without fail, it froze my lap top drove me crazy.
I used a pay as you go system that charges about $12 for 30 way points, but never got a great result.
I think the best way for a web map is using Photoshop, But this is harder.
I still want to do an 'actual route map/ but havn.t found a great alternative.
cam to gif
If you ride like the wind, expect to get blown away. One lifetime is all we get use it wisely this ain;t no practise.
LargeWayRound
Post by LargeWayRound »
Hi Pat
Don't know if you have seen these before , http://www.findmespot.eu/en/index.php
If I was doing your awesome trip then I would seriously consider one , also gives you mapping of your travels . At a cost .
Just a thought .
Cheers Bud
Barcelona Pat
Cheers all - plenty to look at when I get home. Keep it coming!
Edit: I did this on Google Earth:
PATA Globe.jpg (40.45 KiB) Viewed 1635 times
and I have the route tracked on a KMZ file.
Pat
Return to “WEBSITE AND FORUM STUFF”
