Wiring misery
Scrumpymonkey
Has thanked: 18 times
Wiring misery
Post by Scrumpymonkey »
Hi all,
As a good father, I recently purchased a 50cc Rieju bike for my 16 year old son. Being a skint father, I paid £500 for a 13 year old rat. It had a good engine and ran well but no other electrics were working.
I've sorted everything except the dash. This bike runs a rectifier and with a 12v AC output and the previous owner fitted a newer dash which requires a DC supply. Will I be ok to put a converter into the supply circuit to the dash?
Snaf MKII
Has thanked: 958 times
Been thanked: 803 times
Re: Wiring misery
Post by Snaf MKII »
The rectifier should give dc, have you tested the output.
Scrumpymonkey
Re: Wiring misery
Apologies, it's a regulator not a rectifier. Always type the wrong thing.
I've tested it and it's working fine. I just wondered whether there was any issues with using an AC to DC converter in the circuit to the dash.
Has thanked: 1613 times
Been thanked: 1831 times
Re: Wiring misery
Could you convert the lot to DC using an integrated reg/rec?
This will give more consistent lighting at low rpms...you might even be able to use brighter LED lamps without overwhelming the system.
Good selection here
https://www.24mx.co.uk/motocross-parts/ ... Cdm83gF9bi
catcitrus
Has thanked: 100 times
Been thanked: 470 times
Re: Wiring misery
Post by catcitrus »
out of interest whats the difference between the two AC inputs (A and AC) if I remember.
Re: Wiring misery
When I put a new reg/rec on my KTM950 it had 3 yellow wires: apparently the component doesn't care which connection is made to which wire.
I joined them randomly and it worked fine!
Re: Wiring misery
dbl post
Asgard
Has thanked: 179 times
Been thanked: 406 times
Re: Wiring misery
Post by Asgard »
surely it comes standard with a DC reg/rec?,, does it have a battery?
