Alt Rider Synch 14 Litre Dry Bag
The bag has been used a couple of time but now I’ve got the larger one.
This was ideal for storing stuff I needed to get to quickly.
£30 Posted.
This is the info off Alt Rider Site.
The AltRider SYNCH (siNGk) Dry Bags are the culmination of 15 years of off-road camping experience, world traveling, and soft goods design, all rolled into a single easy-to-use and durable package.
Each bag has a fully tape-seam sealed, D-shaped body construction made of 18oz vinyl coated fabric (“Truckers Tarp”). The SYNCH bags are designed to be 100% dust and waterproof, engineered to withstand the most extreme temperatures and wet weather over hundreds and thousands of miles of trails and roads.
SYNCH was designed with accessibility and flexibility in mind. Each bag features daisy chains for easy lashing of camping gear like bed rolls and tents. There are four anchor points with high strength nylon D-rings for strapping the bags to the bike and for connecting bags to each other. All of the anchor patches are made from a military grade, waterproof and chemical resistant neoprene.
Designed for quick entry, the side openings allow access to either of the bags two openings without having to release the tie-down straps. This holds true when the bags are stacked on each other as well.
Each dry bag includes 2 tie-downs, that are 5 feet or 1.5 meters long. Each end of the tie-down features a soft-loop style closure, perfect for attaching to crash-bars, trellis frames, luggage racks and other great tie-down points that connect with snap buckles and is adjustable in length.
Features List:
Capacity: 14 Litres (perfect pannier topper)
Approximate stuffed dimensions: 17.5 x 9 x 7 inches (44.45 x 22.86 x 17.78 cm)
Wide-mouth roll-down opening with cinching straps
18oz waterproof and durable “truckers tarp”
Military-spec neoprene on all anchor patches
Tape-seam sealed construction for water and dust proof performance
Daisy chain(s) for extra gear lash-points
Nylon D-rings for tie-down and stacking
Alt Rider Synch Dry Bag 14 Litre
- Has thanked: 4 times
- Been thanked: 46 times
- IMG_7147.jpeg (217.47 KiB) Viewed 1089 times
- IMG_7148.jpeg (200.09 KiB) Viewed 1089 times
