Rear brake light failure on the XT1200Z
Dark Knight
Been thanked: 99 times
Post by Dark Knight »
Noticed that the rear brake light was not working from the front brake lever on the Super Ten.
The foot brake still operated the stop light, the LED Rear light Assy must have separate LEDs for the stop lights.
Fault traced to the micro switch on the the front brake lever, it had gone high resistance.
Changed the micro switch and the fault has now cleared.
Starting to wonder if the fault was due to the hot weather as the bike has only done 25K miles.
Yoyo
Been thanked: 46 times
Re: Rear brake light failure on the XT1200Z
Post by Yoyo »
Glad you got it sorted, there was a recall for the front switch which was causing cruise control issues but I think it was the opposite fault of what you were seeing.
Sent from my ELE-L29 using Tapatalk
macvisual
Has thanked: 808 times
Been thanked: 729 times
Post by macvisual »
Dark Knight wrote: Sat Jul 23, 2022 6:57 pm Noticed that the rear brake light was not working from the front brake lever on the Super Ten.
Great to see you’re still riding/enjoying the Super Ten…!
Regards;
Pete
Frank Zappa
Dark Knight
Good to hear from you, yes the Super Ten is going well, though it seems ages since I was over on the continent.
Was up north for a week not long ago, I picked the week when the rain was horizontal, still must have been 30 bikes parked at the
old railway hotel at Ulapool, the third floor has been refurbished and the staff are friendly.
Still to get the CBF1000 MOT'd, maybe next week.
Ride safe.
ErikGustav2
Has thanked: 224 times
Been thanked: 990 times
Post by ErikGustav2 »
On older bikes I used to replace the mechanical solution that feels the movement with a hydraulic sensor.
That reacts on the pressure of the brake fluid.
I found a generic one. That had the sensor built into the bolt that holds the hydraulic hose.
M10x1 or M10x1,25 dependent on MC brand.
Easy to mount. Reliable
Dark Knight
Micro switches are usually very reliable, have used them on military equipment in the past, thats why I am wondering why we are getting failures.
mechanic
Has thanked: 13 times
Post by mechanic »
Quality issues, different standards of manufacture. I bet the micro switches used on aircraft are at the very top of the tree!
