USB handlebar charging
chipy
Has thanked: 33 times
Been thanked: 111 times
Re: USB handlebar charging
Post by chipy »
daveuprite wrote: Fri Nov 26, 2021 5:58 pm
chipy wrote: Fri Nov 26, 2021 5:55 pm Make sure you wire it via relay or the transformer will flatten the battery on your bike.
Yes I'm interested in NOT doing exactly that, Chipy. Wouldn't the on/off switch sort that out?
No the transformer is working all of the time to lower the voltage so even if nothing is pluged in it will still drain the battery. Guess how i found out :roll:
bikenav
Has thanked: 1187 times
Been thanked: 761 times
Post by bikenav »
In my experience you be lucky to get 15 months out of one if they are out in the weather, done for a few over the years mounted up on the bars but they are cheap, perhaps they might last longer if not permanently live with the risk of water ingress and 12v. I have a simple one, twin USB no switch wired direct to the battery via a long lead 1 metre or even a bit more all the spare lead gets pushed up where the ABS pump is supposed to live on the GS and the socket sits behind the quick release side panel, its permanent live, only use it for camping and just pull it out and pop the usb end through the tent door for charging camera/phone/headtorch during the night. I disconnect it during the winter non camping season due to the drain issue in an emergency easily reconnected for a quick charge, Works a treat. Did a quick ebay search failed to find one but this one has its merits but I'd prefer a twin if available.
Screenshot (148).png (188.83 KiB) Viewed 1869 times
https://www.ebay.co.uk/itm/233650080023 ... SwiBNfDsiW
bikenav
Post by bikenav »
this is similar to the one I use but mine has a twin USB outlet, to disconnect and save the battery, just pull the fuse.
https://www.ebay.co.uk/itm/393520568349 ... SwbllhH3LP
daveuprite
Has thanked: 2452 times
Been thanked: 3293 times
Post by daveuprite »
Cornishman wrote: Fri Nov 26, 2021 8:39 pm
chunky butt wrote: Fri Nov 26, 2021 8:11 pm Dave what ever you do put an inline fuse in, and waterproof switch so it won't overload, and you can isolate it ;)
If it’s for his Beta there’s waterproof and waterproof. It might be safer buying something through a yacht chandler.
https://www.force4.co.uk/item/Osculati/ ... Socket/9JK
:lol: :lol:
Haha. So true. Actually it's for the road bike, so hopefully it'll get wet very rarely.
daveuprite
Thanks very much for all the suggestions and advice. I like the idea of wiring it so that it only works when the engine's running (or the headlamp would do because that turns on automatically with the key). I just need to find someone who is not as profoundly hopeless with electrics than me to fit it. I need a new haircut after every attempt i make to do anything electrical...
Steve? Could you wire one of these things via the headlamp circuit?
Godspeed
Has thanked: 2587 times
Been thanked: 2202 times
Post by Godspeed »
I’ve been using a quad lock charging cable. Apparently doesn’t draw a current so I’ve wired it directly to my battery. Had no problems so far and today has money off too 👍
https://www.quadlockcase.co.uk/collecti ... 0563993715
The Meandering Moustache
Going Big and Riding Small
Honda PCX125 (sports tourer)
Hugh
Has thanked: 879 times
Been thanked: 929 times
Post by Hugh »
I have used the following company for various electrical 'stuff';
https://www.vehiclewiringproducts.co.uk
daveuprite
Godspeed wrote: Sat Nov 27, 2021 9:32 am I’ve been using a quad lock charging cable. Apparently doesn’t draw a current so I’ve wired it directly to my battery. Had no problems so far and today has money off too 👍
Yeah, I'm thinking about that Chris. I've already bought the Quad Lock mirror stem mount, the anti-vibration mount, the extender thing and the lock thing itself for my phone, so it's all there and in a good position on the bike. Feels very solid and well-made. But that lot was about 60 euros, so I just baulked a bit at another load of cash for the charger mount. And I'd like a dual USB socket so that I can also charge my giant double-ended dildo on my way back from Amsterdam - I'm sure you'll understand...
Godspeed
Post by Godspeed »
Double-endeds are very overrated. It means you actually have to talk to someone else 😉
chunky butt
Has thanked: 54 times
Been thanked: 699 times
Post by chunky butt »
daveuprite wrote: Sat Nov 27, 2021 8:51 am Thanks very much for all the suggestions and advice. I like the idea of wiring it so that it only works when the engine's running (or the headlamp would do because that turns on automatically with the key). I just need to find someone who is not as profoundly hopeless with electrics than me to fit it. I need a new haircut after every attempt i make to do anything electrical...
Yep Dave, take power from the side light or tail light as there on all time with the ignition on, then in line fuse and personally I'd put a switch as well so you can isolate. Reason for this, if there USB they only need to get damp and they'll draw a current, found this out hard way, so if you have the switch you plug in your phone then "switch it on on". Happy days.
