Tarp set ups
POD
Been thanked: 3 times
Tarp set ups
Post by POD »
I'm looking to take a tarp on bike trips when its more than just me to provide a small sheltered area, outside of the tent.
I'm looking online at different set up but would love to see some pictures of everyone's tarp set ups. If you can also recommend good poles for transporting on a bike, that'd be great :)
Sent from my SM-G970F using Tapatalk
Peirre
Has thanked: 21 times
Been thanked: 64 times
Re: Tarp set ups
Post by Peirre »
I’ve recently spent a fortune on a custom 13ft long Superfly tarp, XLC Hammock, Wooki underquilt and other stuff from Warbonnet in the USA, the import taxes are eye watering. https://www.warbonnetoutdoors.com/produ ... ory/tarps/ There’s a uk reseller of WB stock called henge Hammocks if you want to go down the super light route.
https://www.hengehammocks.com/tarps-accessories
But that aside I suggest you look at either the decathlon offering which comes with poles, https://www.decathlon.co.uk/multifuncti ... 44366.html or one from DD Hammocks https://www.ddhammocks.com/product/tarp-xl
If your anywhere near Sheffield/Doncaster I have one of the decathlon ones spare. Have a look at the above and figure out what size you want and you can take it from there
Everything is about your budget, if you want trick nesting poles that fit inside each other have a look at a Dutch company called ESVO camping https://www.esvocampingshop.com/en/tent ... ing-poles/
frenchy3
Has thanked: 367 times
Been thanked: 108 times
Re: Tarp set ups
Post by frenchy3 »
I hammock camp with my motorcycle and i have a DD hammocks 3 x3 tarp. You can set them up with many different configurations.
catcitrus
Has thanked: 95 times
Been thanked: 448 times
Re: Tarp set ups
Post by catcitrus »
I have a Robens tarp--loads of attachment points--and I use the trailer type tarp short elasticated tie downs (with a plastic ball) between the eyelets and the guy ropes on all but the two main ,top guys--plenty of give in a wind. They can be configured many ways with a few extra guy ropes. bargain here as they are ripstop and light. https://www.outdoorxl.co.uk/robens-tarp ... gJqQfD_BwE
if you just want a front extension then these Vango ones work--I use one as well--fleabay 202329851304
for poles etc then Naturehike(Chinese brand) is very good value and these poles are short enough to pack on a bike--and use two, three, four etc--get rid of the elastic in the middle--very light and do the job. Fleabay 303630087135
POD
Re: Tarp set ups
Post by POD »
Thank you all. Definately given me some better ones to look at to use in a couple weeks time :)
Jak*
Has thanked: 364 times
Been thanked: 496 times
Re: Tarp set ups
Post by Jak* »
Decathlon one, I threw the poles away and use a couple of old aluminium ones instead. PrevioiI used an ex army poncho. Cheers
tuftywhite
Has thanked: 45 times
Been thanked: 62 times
Re: Tarp set ups
Post by tuftywhite »
This chap seems to be good at tarp set ups.
https://www.youtube.com/channel/UC6DiGj ... Grw/videos
qcnr
Has thanked: 696 times
Been thanked: 244 times
Re: Tarp set ups
Post by qcnr »
Got a DDHammocks 3x3 tarp. Very good and as mentioned above has many fixing points for various set-up options.
Cheap and good value.
Asgard
Has thanked: 174 times
Been thanked: 381 times
Re: Tarp set ups
Post by Asgard »
Not wanting to start a new thread for one question, so hope you don't mind the intrusion..
Those British army Bashas you see for sale, are they single layer material without a plasticized layer on the inside?
Asking as I want to use it to cover something that gets fairly warm and the last type I used melted the waterproof coating on the inside and it stuck to the thing it was covering..plain polyester or whatever is ok
qcnr
Re: Tarp set ups
Post by qcnr »
As far as I remember the 'British army basha' is a poncho....
Return to “TRAVEL GEAR”
