Ktm 990 adv farkles
Agent Orange
Has thanked: 143 times
Been thanked: 62 times
Re: Ktm 990 adv farkles
Post by Agent Orange »
Just be careful with the ACF50, don't get it on your tyres or discs. Be tight with it. I usually have a cloth in a zip bag that has surplus on, that a rub on the spokes, still go slightly orange mind after a while :o
I expect you use ACF50 anyways, seeing as your bike lives outside.
That's super naughty painting the spokes to hide the corrosion, best to see it, to keep an eye on it.
Has thanked: 1414 times
Been thanked: 1669 times
If you work carefully, and do one spoke at a time, checking the wheel remains true every time, you should be able to replace the spokes yourself.
I've replaced individual spokes on cycle and motorcycle wheels before without wrecking anything. Assuming you use standard spokes, you need a 6.8 mm spoke wrench and the correct torque figure is 5.4 Nm
https://ktmtwins.com/products/ktm-spoke-torque-wrench
Teflon Jnr
Has thanked: 8 times
Been thanked: 107 times
Post by Teflon Jnr »
Agent Orange wrote: โ†‘Sun Jun 21, 2020 11:44 am Just be careful with the ACF50, don't get it on your tyres or discs. Be tight with it. I usually have a cloth in a zip bag that has surplus on, that a rub on the spokes, still go slightly orange mind after a while :o
Yeah been using acf50 for a few years now and really like it I managed to get some on my peg rubbers I wont make that mistake again lol it's expensive but it does a good job I think I have noticed the new cans aren't as good as previous very spluttery the last few I've had.i also use a lot of Maguire carnauba wax makes cleaning a doddle
๐Ÿ‡ฉ๐Ÿ‡ช ๐Ÿ‡ง๐Ÿ‡ช ๐Ÿ‡ฌ๐Ÿ‡ง ๐Ÿ‡ฎ๐Ÿ‡ช ๐Ÿ‡ซ๐Ÿ‡ท ๐Ÿ‡ฎ๐Ÿ‡ฒ ๐Ÿ‡ฑ๐Ÿ‡บ
Agent Orange
I buy it like this
Spray it on the plastics too, then rub it off with the cloth I keep In the bag, I go over the whole bike, with said cloth, shocks, swing arm, clocks everywhere. No need to wax as it comes up great.
That size bottle has lasted me 3 years so far and still has third left in it.
Teflon Jnr
Ooh I will give that a try as I've been using the aerosol version cheers dude hope to see you at the next abr rally
Teflon Jnr
Agent orange took your advice and used a scotch brite removed the spoke cover things and acf 50 and rubbed all the paint and rust of and I'm well pleased well with the back wheel anyway as it took 2 hours so now to do the front thanks again buddy
Teflon Jnr
Before
Teflon Jnr
Another
that looks like it was more 'flung-off' chain lube than rust.
Teflon Jnr
The front wheel is a different story lots of deep rust spots so needs more attention any ideas
Return to โ€œACCESSORIESโ€
