Main Bearings Idenitification
Thedktor
Has thanked: 178 times
Been thanked: 250 times
Post by Thedktor »
Anyone know much about main bearings?
The DR350 has Koyo 6306 but they are marked "SH" with no indication of C3.
Any ideas?
Suzuki ones are very expensive!
- Steve
Southampton area
DR350, 349, DRZ, 701
zimtim
Has thanked: 623 times
Been thanked: 548 times
Re: Main Bearings Idenitification
Post by zimtim »
KTM bearings likewise are expensive
I generally uses one of theses companies
https://simplybearings.co.uk/shop/p1353 ... _info.html
http://proactionsport.co.uk/store/index ... =68&page=2
http://www.wychbearings.co.uk/3206-a-2rs1-mt33_skf.html
Found the guys at Wych bearings very helpful over phone.
I had a bearing where part of number had worn away, have them a call with part of the number and the dimensions they were able to sort
Hope it's a help
byewayrider
Has thanked: 26 times
Been thanked: 80 times
Post by byewayrider »
Solo ktm690 euro trail rider
akendall1966
Been thanked: 2 times
Post by akendall1966 »
They are 6306 as stamped on the sides which is a bearing conforming to international standards if you want to confirm.
C3,4&5 have extra clearance to cope with high heat and expansion, C2 are tighter clearance and would be marked 6306C2. Generally bearings are normal clearance unless marked otherwise. The picture below shows Koyo seem to follow this convention.
https://simplybearings.co.uk/shop/image ... c3.koy.jpg
I an well lubricated system like a engine bottom end standard clearance would be fine IMHO
OD 72
ID 30
width 19
About £8 for branded or £6 for budget, I most use simply bearings as they deliver fast and free
https://simplybearings.co.uk/shop/p1650 ... views.html
AK
Thedktor
Post by Thedktor »
Thanks all for the replies. i too have used Simply Bearings for many years as it happens, so I asked them the same question.
They had not seen an "SH" marking but also suggested C3 types are normally marked.
I'm sure two-strokes I've rebuilt in the past use C3 mains, maybe as they don't have a lot of oil sloshing around they get hotter?
- Steve
Southampton area
SgtWilson
Post by SgtWilson »
SH = Single-row deep groove bearing, wider than standard. From the SKF / MRC handbook.
Thedktor
Post by Thedktor »
Ok..... Thanks, which bit is wider?
- Steve
Southampton area
SgtWilson
Post by SgtWilson »
Simple enough - just check the width of the ones you have taken out and compare it to the specs of a 6306 from any supplier. If they're the same then it must be an internal dimension - and the only width which can now be different is bigger track (and balls). So that might explain part of the cost of a genuine spare.
steve the grease
Has thanked: 8 times
Been thanked: 101 times
Post by steve the grease »
If the races are less deep , then you can have marginally bigger balls for the same external dimensions. I can't see it being more than a couple of millimeters though. Would it make any difference?
Hugh
Has thanked: 940 times
Been thanked: 980 times
Post by Hugh »
If you follow the link below you will see that SH bearings are "Special Heat Treated",
http://www.koyo.com.br/upload/koyo/cat1 ... arings.pdf
I would suggest that you make sure that any replacements you buy are at minimum to the same standard.
Koyo.pdf
(164.48 KiB) Downloaded 102 times
