Well those pesky electrical gremlins are at it again. My heated grips stopped working correctly. They were constantly on despite the controller being an intelligent one that cuts out. Also the controller power lights were not coming on when the button was pressed. Thinking it was a dodgy controller (oxford and have had bad ones) I purchased a new one. Fitted a complete new controller and wires to the battery today and the same issue was there. I think the grips and wires are OK as they are warming up. After spending all day trying to resolve it I gave up and fitted a simple on/off switch wired through a relay. I would however like the controller fitted s it gives the flexibility of different power settings. I am now suspecting the controller is not at fault however. I also plan to swap the controller with the same one fitted to a different bike to test it when time permits
Yet again over to the knowledgeable folk on here.
More electrical issues
Re: More electrical issues
Unfortunately I have not fitted this marque of heated grips although in the past I have watched a number of videos on the all encompassing YouTube. The controller is an 'intelligent' unit that senses the battery voltage to automatically control its own on-off master function by being wired directly to the battery. The theory is that they use Schmitt trigger technology to monitor the battery voltage, effectively above a certain factor they switch on and below that threshold they turn off.
You may need to test the battery and charging system of the motorcycle. Before trying to test any electrical faults I would always test and charge the battery, preferably off the bike or use a charger such as an Optimate, other makes are available. Check all earth connections to the battery as these corrode plus they can loosen over time and cause all sorts of problems.
I think that you might be best advised to contact Oxford products direct and to that end take a look at their website;
http://www.oxfordproducts.com/contact
Sorry I do not have the definitive answer to give you but perhaps these comments might help.
Please let us know how you get on.
- Mickdb1
- Has thanked: 8 times
- Been thanked: 85 times
Paul the oxford grips = first ones were known to have dodgy controllers. Maybe a search of Repair um or ever ask Oxford for a replacement goodwill do dah = yer never know !!!!!!!!!!!!!!!!!
HTHY
HTHY
Hugh wrote: ↑Tue Dec 19, 2017 10:02 pm Greetings,
The problem was that the grips would not turn off and the controller was not controlling or lighting up. The battery had been on a trickle charger all night and showing fully charged. I think there may be a problem with one of the grips having thought about it which I am hoping to prove by swapping the controller to another set of grips. I will of course keep you posted.
Hi Mick, long time no see. You still got your Sertao? My old girl is starting to show her age and mileage but I am loath to part with her. Just fitted the Touratech rear shock on her as well as mine was getting very tired.
I have purchased a brand new controller and I am still seeing the same fault on the new controller which only leaves the grips which I will prove tomorrow by swapping a controller as mentioned above. I think the wiring may need some work in general as I am starting to see a few electrical problems.
- Has thanked: 2280 times
sounds like your `intelligent` controller needs re-educating,
to some degree,
don't overfeed it the volts
or it will become the fat controller
(apologies)
to some degree,
(apologies)
- Has thanked: 572 times
- Been thanked: 894 times
ive had a similer problem ..ive used oxford grips for a long time and have em on all the bikes ..they have ben on the wee strom for ten years and the grips are worn down to the wires i just wrapped em with tape an they still work well
point being that they usually work pretty well
been on the rally for 6 months and like you the controler went haywire ..woudnt switch off and one grip was much hotter than the other
heres a tip for buying
viewtopic.php?f=24&t=45144
so they sent me a new set ..i promtly installed the new controler ....but it did the same ..wouldnt auto switch and no power at all,l to the right grip despite the voltmeter saying all was good ??
out came the dremmel and i fitted the new grip and ... and the controler worked properly again ?
i can only reason that the controler is sensitive to resistance or some other witchcraft electrical shit i know nowt about
good luck ... merry xamas
minkyhead wrote: ↑Wed Dec 20, 2017 12:32 pm ive had a similer problem ..ive used oxford grips for a long time and have em on all the bikes ..they have ben on the wee strom for ten years and the grips are worn down to the wires i just wrapped em with tape an they still work well
[/quote
Thanks Minky, that supports my theory and today I found a dodgy connection on one of the grips which was still contacting though. I haven't however re-fitted the controller yet to test my theory. I will keep people posted.
