Although I'm a self confessed camp cooker junkie (8 cookers at the last count :whistle: ), most of them are fairly old liquid fuelled devices which while they have great charm are a bit of a faff with pre-heating and temperamental simmering etc.
Up to now, my weapon of choice for bike camping has been a fairly modern Coleman Petrol stove which while it has served me well, is a bit of a big heavy lump. However as I find myself wanting the convenience and controllability of gas (along with the ability to cook 'carefully' inside a tent porch) I've been using an ancient Camping Gaz 'bluette' canister top burner more and more.
With this in mind, I've been looking for a reasonably light, reasonably compact, remote canister gas only stove which has a preheat coil meaning it has good performance and can be used in cold weather (invert the canister so it feeds the stove with liquid fuel which vapourises in the pre-heat coil - no loss of performance in sub-zero temps).
After much 'deciding' I've ended up with a Primus Gravity II EF.
Legs in the collapsed position:
It's not a super light, super compact backpacking device but it's pretty light by cooker standards and collapses small enough to fit inside my MSR pan set (especially if you disconnect the preheat coil - just a knurled thumbscrew)
Performance wise it seems great - loads of power if you need it (a 3 kW burner) and very controllable down to a very low simmer. Unlike nearly all its competition It also has a wide mushroom burner which gives a nice broad flame spread (no carbonised lumps in the centre of the pan from a narrow burner which superheats a 1" circle
![Wink ;)](./images/smilies/icon_e_wink.gif)
cheers
M
