We moved into the property in September and the last owner had the garage built around 11 years ago, he used it for basic joinery so had a decent amount of tools in there and never mentioned any problems.
Garage is detached, single skin brick with a tiled pitched roof and concrete floor. it has an up and over door (this has around an inch gap across the top and small gap down each side). there is a solid wood access door to the side. Again with around an inch gap underneath.
Ventilation should be good so why is the moisture attacking my pride and joy?
The garage also has a window at the far end so this afternoon when i put the bike away i opened it slightley and locked it on the ventilation setting.
PS.... ACF50 is on order
Richard
