What is high mileage?
I am enjoying seeing all the new bikes come out year after year with all the brilliant gizmos etc, but I would like to know what bikes us lot have that have done bigger mileages? Can we look after a modern engined bike and keep them forever, I love my 990 and at present I have done 38k, I have put it up for sale twice and twice pulled it back now vowing to keep, put a pic up of your cherished machine with mileage and any major engine repairs needed
Daz
- image_2016-09-13.jpeg (64.12 KiB) Viewed 2341 times
- Has thanked: 337 times
- Been thanked: 153 times
Re: What is high mileage?
45k on the tiger and I've just had the suspension renewed expect to double that mileage at least
Cheers Spud
Cheers Spud
- Has thanked: 76 times
- Been thanked: 123 times
Hiya
A 2005 Pan European, 93,000 miles - had to replace the water pump cover due to a corroded connector pipe, that's it so far - owned from new (thumbs)
Harv
Harv
- Has thanked: 105 times
- Been thanked: 71 times
I had a 955 Sprint ST for 9 years/65k miles.Engine wise all I did was check the valve clearances every 12k miles,they didn't need adjusting for 48k.
The GF's "cheap chinese" 125 also has 23,000 miles on the clock. It burns a little oil otherwise it runs just great.
Bikes And Travels
My s10 now has 75000 in 5 years
friend`s FJR has just done 260000
My 1994 AT (not a modern engine!) has clocked up 77000 miles and sounds sweeter than ever I had the valve clearances and carbs adjusted this summer as they haven't been touched since 48000. The mechanic said they were almost spot on! Compression is perfect on 1 cylinder and a tiny amount down on the other. The only thing I've had to change is the rectifier. I changed the points on the fuel pump just in case. It was working fine but didn't want to push my luck whilst on Pyrenean trip. From what I gather 100,000 shouldn't be a problem. Just as well as I can't afford a new bike;)
N.
N.
