Been out all day final checking of clue points, everything cool, check on here see Al has moved the suggested lunch halt 12mls uh thanks Al, not to worry we will loose one point and an easier day for you.
Will post a GPX file of the clue points and some other odd info tomorrow night after speaking to Al, for those unsure of this method I will put up a practice file here for you to try, if you have either basecamp or mapsource they should open it automatically if you click on it, if none of this works for you there will be a paper copy at the start to copy from.
Clicked some snaps off today to wet your appetite for those going this way.
Ok lets see if I can get these up
you may want to go carefully here
Treasure Hunt
- Has thanked: 1187 times
- Been thanked: 761 times
Re: Treasure Hunt
the ford and bad road have easy alternatives although as you can see they are not difficult themselves
the care there might be worth it for this kind of thing
Re: Treasure Hunt
this website can be a pig at times
your effort might be worth it for this
- DSCN0415.JPG (46.7 KiB) Viewed 11946 times
- DSCN0403.JPG (37.88 KiB) Viewed 11946 times
- DSCN0334.JPG (58.14 KiB) Viewed 11946 times
Re: Treasure Hunt
the gpx file this is just something to play with for the unsure me as well!
more tomorrow night hopefully
Pob lwc!
Good luck
Pob lwc!
Good luck
Re: Treasure Hunt
here are the treasure hunt clue locations for those that may want them
I also have a route to join them up if anybody wants that.
- Has thanked: 143 times
- Been thanked: 62 times
Re: Treasure Hunt
Top man, my Zumo has given up the ghost after 8 years long service..I need to try someone else's battery first.. before I bin it.
Tried everything that you can (reset, battery out, on the bike, in the conp, mains etc) reckon the screens spat its dummy out..
May have to have a hard copy I reckon or follow someone else!
Re: Treasure Hunt
Sorry all, appeared to have missed Pt 7 on that file so please use this one there is no Pt 11 by the way.
The Blue flag Pts are Clue locations
The Green Spots are other scenic locations nothing to do with the Questions
There are some other waypoints for general information
There are 50 waypoints, 20 of which are clue points no Pt 11
Cone the file you previously downloaded was intended as a practice run for both myself and others out there so please overite it with this one
