Motorcycle power distribution block?
- Has thanked: 8 times
- Been thanked: 96 times
Re: Motorcycle power distribution block?
Nip over to me once I'm back from Ireland Steve I'll build you one to your spec, I did mine with three outputs, only two switch from the ignition but a physical switch forall three so I could chuck current back down it and charge the bike if I wanted to (thumbs)
Cheers Rich, that is very kind of you... (thumbs)Mad Hatter wrote:Nip over to me once I'm back from Ireland Steve I'll build you one to your spec, I did mine with three outputs, only two switch from the ignition but a physical switch forall three so I could chuck current back down it and charge the bike if I wanted to (thumbs)
Are you holidaying in Ireland then?
I am all for spending money on quality parts, but these are used on rally bikes in every kind of extreme weather and terrain you can imagine and perform flawlessly. They're under the seat either, they're fully exposed.
http://www.durite.co.uk/itm/Fuse-Box-fo ... use/023440
They're about 12 quid.
No worries mate, any excuse to get the soldering iron outSteveR wrote:Cheers Rich, that is very kind of you... (thumbs)Mad Hatter wrote:Nip over to me once I'm back from Ireland Steve I'll build you one to your spec, I did mine with three outputs, only two switch from the ignition but a physical switch forall three so I could chuck current back down it and charge the bike if I wanted to (thumbs)
Aye leaving Friday and sailing on Saturday for a week over there with the mrs and Nikoli. Forgot how hard it is to pack a bike for two fo more than a weekend :blink:
Needs an account on the linked site, but similar/identical kit on fleabay at around 15 quid... Thanks Mike (thumbs)Mike54 wrote:I am all for spending money on quality parts, but these are used on rally bikes in every kind of extreme weather and terrain you can imagine and perform flawlessly. They're under the seat either, they're fully exposed.
- Has thanked: 2 times
- Been thanked: 84 times
No doubt the 30 / 40 pound items are great but I'm a cheapskate so went for a 4.99 jobbie from halfords and looped out the one side to give a feed to all the fuses. Will dig out a pic.
Yamaha tenere 700
I don't want to google "Eastern Beaver" from my work laptop.
I've used the relay/fuse block that's in this eBay listing:SteveR wrote:I am looking for one to tidy up the rats tail mess under the seat of my trail bike. Does not need to be switched from the ignition, although it might be nice! Individual fused outputs nice, but again, not essential.
Can any one recommend a unit and supplier please as I am struggling to find one!
http://www.ebay.co.uk/itm/12V-40A-4-pin ... g_ToRDsTow
It's quite compact and gives me three switchable, fused outputs; or it could be configured to give a mix of switched and non switched (of course you need to sort out the earth separately).
