I've got two riding jackets, one leather and one textile. One has the standard yellow foam type armour, the other has a softer foam but with rigid plastic reinforcement. Given the armour's removable from both and I can swap them round, which is better? So for winter I wear my textile touring jacket, and I'm trying to figure out if I should put the hard plastic armour in it.
Any input appreciated.
Which armour?
Oop North John
- Has thanked: 154 times
- Been thanked: 199 times
Re: Which armour?
Whichever has the higher rating is probably better, assuming if fits well, and covers the area it's meant to. D30 armour is quite floppy till you hit something with it, not that I've tested that claim yet.
Re: Which armour?
1+ on D30 also haven`t tested it but very soft and supple until you hit it with your knuckle when it hardensOop North John wrote:Whichever has the higher rating is probably better, assuming if fits well, and covers the area it's meant to. D30 armour is quite floppy till you hit something with it, not that I've tested that claim yet.
