XR400 is it any good ???
Mad Hatter
Has thanked: 8 times
Been thanked: 96 times
Re: XR400 is it any good ???
Post by Mad Hatter »
Kirky1298 wrote:Bumpety bump !
Anyone know what the blue thing pictured is ?
Got any more picture of it, like one of the end not with the crimps? Looks a bit like a buzzer or something, indicator relay with a buzzer to let you know its flashing maybe? Or alarm/horn? What is it wired into?
Not sure about the other one, unplug them and see what doesn't work :lol:
Kirky1298
Has thanked: 7 times
Been thanked: 10 times
Post by Kirky1298 »
Ahhhh, the common sense approach, why didn't I think of that (thumbs)
Mad Hatter
I wouldn't worry its normally something I bypass entirely :lol:
Kirky1298
Post by Kirky1298 »
Ok,
Just put the bike on the table to adjust the chain...............
Please tell me the front sprocket os supposed to float around on the countershaft
I.E. Loads of side to side movement on the shaft ?
Scott_rider
Has thanked: 29 times
Been thanked: 294 times
Post by Scott_rider »
No, it shouldn't do that.
Is the sprocket nut correctly tightened and secondly, is there a flange washer? (I can't remember if the XR has one)
Kirky1298
Post by Kirky1298 »
It has a wee oval plate with 2 x 10mm nuts holding sprocket onto shaft and these appear to be tight. Here's a video of the free play, sorry, don't know how to embed video.
Scott_rider
Ah...yes, I remember, it doesn't have a central 'nut' that holds the sprocket onto the shaft, does it? It's just held on by the plate with two bolts either side? If so, then it will have movement so unless it's absolutely rocking from side to side by a really excessive amount it will be fine. I think some of the XRs have this system and some have a conventional 'nut' with a flange washer and in that case the sprocket doesn't move sideways. I had the first system with my XR280 and I thought wtf when I felt it moving...!
check this out...
sprocket movement
Kirky1298
Post by Kirky1298 »
Thanks for that, I'll just put it back together and hope for the best. (thumbs)
Has thanked: 330 times
Been thanked: 634 times
Post by Tramp »
Sure most hondas have a little movement ..when it heats up it expands...my ccm has loads of movement...but thats a suzy lump...
Check the splines arwnt fubared...just watched vid..try a new flange as they are supposed to be replaced with new sprockets..not expensive and do wear...
johnnyboxer
Has thanked: 100 times
Been thanked: 523 times
Post by johnnyboxer »
Oval flange is £3 and only available from Honda (thumbs)
