Do you use TYRE TomTom Software?? I am having issues!
Re: Do you use TYRE TomTom Software?? I am having issues!
Just plug in the USB port with a cable, it'll show on the computer as a drive, browse to the ITN folder, and save in there as an ITN file.
It does not appear to export in the gpx format Memory Map likes whilst Tyre can.
I can sketch a rough track in MM export as a gpx file to Tyre that will make a proper track then re export to MM as a gpx so I have my track on an OS map.
@ChrisJK - I'd like to know a bit more about that if you could help me out. That would certainly be the preferred option for me.
- Been thanked: 1 time
I use tyre all the time, it's a brilliant, easy to use route planner.
I don't use it to do the actual route plan though, I plan it all on google maps, then copy the link to it in to tyre via add file from website, then save it as a .ITN file, then send it to your tomtom.
I send my files by removing the tomtom sd card and inserting it in my PC, copying the file across them put the card back in the unit.
Current bikes...
- Has thanked: 52 times
- Been thanked: 158 times
This is Parallels http://www.parallels.com/uk/ and there is also Vmware http://www.vmware.com/uk/products/fusio ... tures.html
I have used both but for the last couple of years just Parallels. It is installed just like any Mac app, then when launched you can install a copy of Windows (or Linux or any of several OS's ). You do need to have an install disk or download of Windows and I am still using Windows 7 although these Vms (virtual machines) will run the latest versions including Windows 10 Beta.
Thereafter when you want to run Windows you just launch Parallels and away you go. As the name implies, you can run Windows in parallel with any other Mac app. You can drag and drop files from Mac apps to and from Windows. Have a look at these videos. http://www.parallels.com/uk/products/desktop/
The Windows installation just ends up as a big file (size dependent on what you specify as the desired size of your virtual machine (I typically run about 50GB which is plenty for my needs) which you can treat pretty much like any other file on your Mac.
Tyre/ Memory Map interchange works OK on my low horsepower Bush win 8,1 tablet, not lightening fast but quite adequate with both programs running.
Hey up!Ginger wrote:@Treadtrader - On the Motogoloco can you export the routes to TomTom Rider13?
I've not tried a Rider 13 (yet) but as long as it's got either an SD card slot or USB connection (i.e. some way of connecting it to your computer), then yes - you should be able to create & save your routes, then export them as a .ITN file (ITN for TomTom/GPX for Garmin) to your device.
Happy to help if you get stuck - just drop us a PM.
James @ MotoGoLoco
