It may well be under the being and add ons that have been put on it shame really cause now iam looking at something else but debating on whether to keep or selldaveuprite wrote: ↑Thu Apr 08, 2021 10:26 pmLooks great. Is it a Honda by any chance?Mikekitts81 wrote: ↑Thu Apr 08, 2021 8:15 pm Put some new bling foot pegs on ....20210407_191843.jpg
- Mikekitts81
- Has thanked: 10 times
- Been thanked: 57 times
- Has thanked: 1404 times
- Been thanked: 652 times
My Wife's MT07 has been on Sorn but with the sun shining and the promise of getting out again soon I rode it for it's first MoT since June 2019 . The 15 mile round trip out towards Mallory Park and back was just glorious .
The garage was really quiet so after putting her bike away I rode my Himalayan over for it's delayed first MoT .
Same route but on different bikes with a different ride, great to be out again.
- Has thanked: 159 times
- Been thanked: 742 times
I took her to the coast.
She needed some fresh air and views.
- A3_Fotor.jpg (111.69 KiB) Viewed 1861 times
- A2_Fotor.jpg (124.49 KiB) Viewed 1861 times
- Has thanked: 1177 times
- Been thanked: 727 times
Replaced brake lever, adjusted wheel alignment, replaced horn and backed off the steering head adjuster a bit, which went surprisingly well.
Suzuki DR200 Djebel.
- Has thanked: 689 times
- Been thanked: 898 times
Checked the fork oil level, one slightly too high and one slightly low, so used a syringe to lower overfill and top up the other leg, it runs ATF. Only checked because of one harsh bump but had more to do with the road surface than the bike but gives peace of mind when checked. After riding crf trailbike the cbf roadbike suspension always feel a bit harsh. Our roads are getting so bad that the trail bike feels at home on whats left of the tarmac
Got the 125 through its MOT
Then after testing the DR200 through the ford on the Fosse Way I changed the oil and fitted some barkbusters. Been a while since I changed oil and dropped my socket wrench in it!
Advice needed: sometimes when I press the back drum brake at speed there is a big clunk. What causes it? I'll take it apart tomorrow and see what's up.
- Has thanked: 1414 times
- Been thanked: 1669 times
Clunk...there's play somewhere. Get the back wheel in the air, and try rotating it back and forth with the brake on. Look and listen. Check the torque arm and wheel-bearings first. If they are OK, then it's wheel out and look at what horror there might be inside the drum.
Richard Simpson Mark II wrote: ↑Tue Apr 27, 2021 9:52 pm Clunk...there's play somewhere. Get the back wheel in the air, and try rotating it back and forth with the brake on. Look and listen. Check the torque arm and wheel-bearings first. If they are OK, then it's wheel out and look at what horror there might be inside the drum.
Ha!
