honda xr headlight size?
Has thanked: 330 times
Been thanked: 641 times
Post by Tramp »
Hi guys ..
you that havee had xr's do you know if the headlights are the same across rthe range fron 250 to 650 and use the same mounting system..side bolts...
and are they all plastic or later models glass and they all use the 35w bosch bulb not 55w halogens...need info for a project...
thanks..
has anyone got one cheap like mount surround...lol
Rob 110
Has thanked: 5 times
Been thanked: 5 times
Re: honda xr headlight size?
Post by Rob 110 »
'95 XR6 i had was glass 35w
iirc euro model xr250/600 were all the same larger ones
earlier USA models and imports had the smaller size plastic ones
other idea is XL600 as that would be similar large size too
Mid Wales Trails offroad tour guide: Barmouth, Llangollen, Dolgellau, Rhayader, Llandovery, Monmouth, Shropshire.
PM for details or click: SweetLamb Adventure Bike Academy
https://imgur.com/ZTqhFlL
Post by Tramp »
cheers Rob..
those transalp lights are very expensive and break easily :( or do you mean the non v twin xl600...
its for the ccm..lol
Will
Has thanked: 13 times
Been thanked: 6 times
Post by Will »
Hi Tramp my xr250 was glass lens and xr400 plastic if that helps , as you will be cutting hole have you thought about those projector lights ??????????? more powerfull and use less current one for dip both on high ????
Bsa A10
Post by Tramp »
WILL..temptation without a link is so so BAD :P ...
so come on spit it out...
Will
Post by Will »
Can't find ones I saw now but these are similar but bulbs not LED not sure if ccm has much spare power ??? http://www.ebay.co.uk/itm/Projector-Spo ... 231d9279f9
Bsa A10
kilmi
Post by kilmi »
hi tramp I had an xr250 and the head light a the same.
Rob 110
Post by Rob 110 »
Tramp wrote:cheers Rob..
i meant the halogen xl600r or xl600lm (some of these were twin lamp)
like this bargain http://www.ebay.co.uk/itm/xl600-m-headl ... 1c35140f52
mmmmm? http://www.ebay.co.uk/itm/Honda-XL600-H ... 19dfc3614b
picos mestizo
Post by picos mestizo »
Will wrote:Can't find ones I saw now but these are similar but bulbs not LED not sure if ccm has much spare power ??? http://www.ebay.co.uk/itm/Projector-Spo ... 231d9279f9
Freewind Engine. Generator = 175w.
Not massive but adequate for a 55w headlamp bulb & a couple of GPS's
Lightness is everything.
