Good man kenny87, looks good and secure.
Managed to steal a hour for the man cave today. I got pannier #2 done
I think my twin is pleased with the progress. :laugh: :laugh:
Project pannier build.
Re: Project pannier build.
Kazakdan wrote:Have you heard of macrolon? I was recommended it but never used it myself. It can be heated. And bent into mounting hooks but locking still a challenge.
Thanks Kazakdan, I'll look into that.
Gerry
Ok folks, a quick update.
Made an attempt at one base. Now I knew in choosing the double 45 degree's, the bases and lids were going to be present some problems. It took me a while to figure the cuts and with the help of my daughter and her tec graph skills we got it sorted.
It is not a tight fit as the bends are more curved rather than a perfect 90.
I'll post photo of the cuts in the next post.
Doesn't look too bad from this side.
I suppose I could use plenty of silicone to seal the gaps and I intend to line the boxes with a thin layer of foam or the like, so it won't be noticed.
That it for now.
Cheers.
That it for now.
Cheers.
You need something heavy, square and hard. A piece of wood would do at a push but metal would obviously be better. Holding it against the inside of the bends, gently tap the outside with a hammer and you'll soon tighten everything up. I've seen worse with 50 grands worth of bending machine so seriously well done!
Also, ratchet strap around the bottom of the pannier will pull everything in while you get everything fixed in place
You have a pm btw
You have a pm btw
And one sent back. Cheerskenny87 wrote:Also, ratchet strap around the bottom of the pannier will pull everything in while you get everything fixed in place
You have a pm btw
Well got another bit done today. Made the base for pannier #2
Here's a few pics of the cuts and bends required as promised.
I am waiting untill I have everything together before I assemble them.
Seals for lids on the way from here, http://www.sealsdirect.co.uk/listDepart ... teAreaId=1
Latches/locking systems from here, http://www.protex.com/product/index/cat ... +Fasteners
I also had a go at the top box, I tried this in one complete sheet.
I'm sorry now that I didn't do the panniers like this. It would mean less rivets, sealant and less chance of leakage..
Ah well you live and learn.
Gerry
Gerry
Well, I've been working away at my boxes over the last couple of weeks, when I could steal a hour or two. Been busy with a 21st (not mine unfortunately) and getting the house ready and all that.
Anyway, I'am nearly there. Boxes are assembled and lids are made. I just need to get the seams on the corners welded.
Really happy the way this worked out. :thumb:
Looking Great. You should be very pleased with your work. As you have saved a bundle on these and celebratory drinky is well in order :cheer:
