A photo you took, today
- Has thanked: 18 times
- Been thanked: 80 times
Re: A photo you took, today
New tyre on order got the tube. Thought I’d practice these scorpion rally’s ar bast—-do to break the beads. Anyone got any tips
- 2767EC84-2352-475F-B4B8-CC12A3B8C44D.jpeg (255.05 KiB) Viewed 1328 times
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
This is not my video Mark but this is what I use, it's a great bit of kit.
one-legged adventurer
- Has thanked: 1414 times
- Been thanked: 1669 times
You need a WIDE tyre lever, and an adjustable spanner
Squeeze the tyre lever flat between the rim and the tyre.
Clamp the adjustable on the tyre lever at 90 degrees to the length of the lever.
Use the adjustable to rotate the lever 90 degrees, so as it turns it pushes the tyre off the rim.
Or put the wheel flat on the ground in front of a car wheel...lined up so the car wheel will run over the tyre but not the rim.
Drive the car onto the tyre.
Or put the tyre in a vice and tighten the vice.
Or go to a motor cycle tyre shop,and give the nice man £15 to do it for you.
I've used all the above methods....the last one is the easiest.
- Has thanked: 754 times
- Been thanked: 632 times
Link to Bob's vid of breaking a bead.
This isn't me...it's nothing to do with me...don't blame me if you try this and it ends in disaster
