- Has thanked: 2452 times
- Been thanked: 3293 times
Oil filter, air filter, engine oil change, clutch oil change, hydraulic clutch bleed and fresh DOT4.
All ready for crashing it into something tomorrow at Steve's.
- mark vb
- Has thanked: 329 times
- Been thanked: 697 times
Time to get my '98 Africa Twin back on the road after 6 yrs unused, having used its wheels elsewhere in the interim. Started off with dismantling the rear shock linkage to clean, check and re-grease - two of the bearing dust seals had some deformation on their lips, so renewed them. Also removed the chain and final drive sprocket, with new C&S kit on order, and checked the final drive shaft splines, which remain fine. SMPro wheels have been checked, the rear having being re-spoked, ready for me to fit new tyres and balance.
- 20210320_212013.jpg (191.96 KiB) Viewed 1944 times
- 20210314_165226.jpg (192.01 KiB) Viewed 1944 times
- 20210320_213245.jpg (173.68 KiB) Viewed 1944 times
- boboneleg
- Has thanked: 2372 times
- Been thanked: 1416 times
Shaft splines still look goodmark vb wrote: ↑Sat Mar 20, 2021 9:40 pm Time to get my '98 Africa Twin back on the road after 6 yrs unused, having used its wheels elsewhere in the interim. Started off with dismantling the rear shock linkage to clean, check and re-grease - two of the bearing dust seals had some deformation on their lips, so renewed them. Also removed the chain and final drive sprocket, with new C&S kit on order, and checked the final drive shaft splines, which remain fine. SMPro wheels have been checked, the rear having being re-spoked, ready for me to fit new tyres and balance.
one-legged adventurer
- mark vb
Yeah, the occasional times I check the splines is always with some trepidation as they do have a bit of a reputation.... some of the photos posted on xrv.org have been horrific. But staying with an OEM sprocket & 70mm* or so of slack seems to pay off for keeping them in good shape. I really don't fancy having to replace the output shaft, if they're even still available!
*70mm from the underside of the swing arm to the chain under tension, at the centre point.
- Has thanked: 18 times
- Been thanked: 80 times
Fitted a dart fly screen. More cosmetic than wind resistance.
- 7AF7D08C-0C46-4DA2-A1DD-083E6CFA43EA.jpeg (208.09 KiB) Viewed 1819 times
- 3469156C-E377-4208-9392-874E70A12B97.jpeg (217.72 KiB) Viewed 1819 times
- Mikekitts81
- Has thanked: 10 times
- Been thanked: 57 times
Put some new bling foot pegs on ....
Looks great. Is it a Honda by any chance?Mikekitts81 wrote: ↑Thu Apr 08, 2021 8:15 pm Put some new bling foot pegs on ....20210407_191843.jpg
- Has thanked: 1427 times
- Been thanked: 1677 times
Put some fresh brake fluid in my Gas Gas clutch...and I can find neutral with the engine running again!
- Has thanked: 201 times
- Been thanked: 272 times
I looked at the bike as I walked past it in the garage this morning I bought it in Sep still haven’t ridden it it’s still only got 363 miles on it
