How "NOT" to Husky
Simon_100
Has thanked: 44 times
Been thanked: 112 times
Re: How "NOT" to Husky
Post by Simon_100 »
Wow, that's really coming along. Well done - don't forget a Youtube of the first start-up (thumbs)
Simon
HU55KY
Post by HU55KY »
Thanks for the encouragement!
The sleeves on the swing arm were on the wrong way, swapped to the inside and the swing arm fitted the frame no problem.
However, the new bearings in the swing arm link won't fit inside the swing arm :pinch:
The two pieces of the link fit together and the link will fit the rear of the frame but not the swing arm?!
I've spent a couple of hours thinking it's got to be me and my lack of know-how but I just can't get it to fit.
Back to the shop where I had them fitted... :(
herman
Has thanked: 878 times
Been thanked: 632 times
Post by herman »
Does the link have washers/spacers too? The KTM shocks can be a swine to fit after new bushes as the washers have a foam washer behind which needs compressing with a small clamp to fit into the frame.
HU55KY
Post by HU55KY »
Hello Herman,
The needle roller bearings have a metal sleeve and then a plastic coated seal at each end with a thick (3-4 mm) washer inside them.
If they were 1 mm narrower the link would fit the swing arm.
HU55KY
Post by HU55KY »
With the washer...
Without...
HU55KY
Post by HU55KY »
I took the link on one side and had a word in it's ear...
New front and rear sprockets fitted too.
The injection inlet manifold is appreciably larger than the old carb inlet...
Internal diameters are 65mm v's 48mm.
The old manifold fits inside the new with a 2.5mm gap between the two so there's some opportunity to fit the two together if I can find a suitably sized rubber hose with say a 2mm wall thickness. :whistle:
And there's a box of goodies on it's way from Huskysport to keep the project rolling. ;)
Dutchgit
Has thanked: 40 times
Been thanked: 5 times
Post by Dutchgit »
Why not fit injection ? Could make things easier and better ?
HU55KY
Post by HU55KY »
It's an idea Dutchgit but not one I've priced up?!
Maybe I could upgrade in the future, with the cash I'm throwing at this project right now I don't fancy the idea so much as a piece of rubber hose.
Thanks for the thought though... (thumbs)
kev.t
Has thanked: 70 times
Been thanked: 21 times
Post by kev.t »
nice project pal.
for someone who didn't even have a decent set of spanners at the beginning, you're doing remarkably well (thumbs)
bowber
Has thanked: 34 times
Been thanked: 179 times
Post by bowber »
What was wrong with the old motor? Bit of JB weld would have seen that running again :whistle:
HU55KY wrote:
f17th wrote:Hope you didn't pay too much for it...
You can part out the rest of the bike for reasonable money on Ebay or source a second hand engine.
Pretty sure you can chuck in a 450 / 510 engine as they are the same fitment, just a different barrel & piston.
The CafeHusky forum is a good source of knowledge, there's a good amount of following and racing going on in the USA.
HuskySport in Winchester (UK) are good for getting spares if you need anything.
Speak to Reece on the parts desk. He's very knowledgeable.
Good luck with whatever you decide to do.
Gav
Thanks Gav,
I'd rather find a second hand engine than break it up for parts...
The damage has gone in to at least one of the valve seats so the heads shot :pinch:
...and some other parts aren't quite as straight as they once were :S
at least the rear shock is off and the swingarm so there's plenty to do... (thumbs)
Return to “HOW TO..........”
