YepTonibe63 wrote:That's my experience too JB, albeit with the 1200gs.johnnyboxer wrote: ↑Sun Jul 30, 2023 9:36 am It’s not the shock
Creaking when you push down on the seat is the pivot bearings
Creaking is pivot bearings
KAIS performance in Atherton, Manchester are the tops for Ohlins supply and serviceadventure steele wrote:Forgot to add clocked a few things on the shock so glad I looked at it the lower bush doesn't look to healthy same for the top one, there's a nick in the Hydraulic hose outer sleeve, an when your hand is on the shock spring pushing on the seat you can feel vibration through the shock.
If the pivot bearings have gone with the shock off can you usually still hear the sound? When moving the shaft through its travel?
N finally who's everyone using for Ohlins rebuilds now adays.
Gonna look at getting them done as a matter of course as it doesn't look like they have seen any attention for a few years.
Top one was worse.
My instinct is saying shock but ill check the Pivot bearings out anyway while it's in bits.
