Battery Purchase License
diggermanbob
Has thanked: 803 times
Been thanked: 534 times
Re: Battery Purchase License
Post by diggermanbob »
I belched thus morning and my grandaughter said Grr. Amps sounds like you got acid ,we need to rectify that , lets charge off down the chemists in the volts wagen. :lol:
WIBO
Has thanked: 618 times
Been thanked: 655 times
Post by WIBO »
FFS
Will It Buff Out?
WIBO
Post by WIBO »
Did you have to drive far from ohm to the chemists or is it close by?
Will It Buff Out?
sprintster
Has thanked: 105 times
Been thanked: 71 times
Post by sprintster »
Sorry for the negativity but I'm not taking part in this discussion.Yuasa all a bunch of idiots!
WIBO
Post by WIBO »
FFS
Will It Buff Out?
andrew882
Has thanked: 56 times
Been thanked: 49 times
Post by andrew882 »
The closest chemist to me is a long drive away. Only really worth going Faraday out.
WIBO
Post by WIBO »
FFS!!!! Good one
Will It Buff Out?
bill_qaz
Has thanked: 689 times
Been thanked: 898 times
Post by bill_qaz »
It makes more exciting if you go from ohm to the chemist in a circuit, you can get a short break at a heatery and dynamo, when you are recharged you can start again but if its cold check your insulation and make sure you have an atom. I am positive this will be current, but you have to sign or wave if you oscillate from the direct current route. You must have been shown the circuit diagram when you took your tesla so do not be confused and blow or trip. Once you are switched on you will buzz through it in a flash being a bright spark and having an amplitude of fun without much resistance. Diode always used to say follow the bright light not the dull glow that will be bad for the earth.
Matron my crayon has run out can I have another :lol:
diggermanbob
bill_qaz wrote: Mon Jun 18, 2018 10:08 am It makes more exciting if you go from ohm to the chemist in a circuit, you can get a short break at a heatery and dynamo, when you are recharged you can start again but if its cold check your insulation and make sure you have an atom. I am positive this will be current, but you have to sign or wave if you oscillate from the direct current route. You must have been shown the circuit diagram when you took your tesla so do not be confused and blow or trip. Once you are switched on you will buzz through it in a flash being a bright spark and having an amplitude of fun without much resistance. Diode always used to say follow the bright light not the dull glow that will be bad for the earth.
I think we are all as mad as a box of frogs :lol:
Cone
Has thanked: 156 times
Been thanked: 252 times
Post by Cone »
I can’t believe this thread has been so positively charged!
