Recommend me a smartphone under £150
Ktmbrock
Has thanked: 12 times
Re: Recommend me a smartphone under £150
Post by Ktmbrock »
I want to order another MOTO G4 (great phone ) the codes used before don't work , anyone got any current voucher codes ????????????
have goggled for codes but nothing seems to work
cheers
brock
SteveR
Has thanked: 288 times
Been thanked: 107 times
Post by SteveR »
After being a big fan of the Moto G range, I have become a little less enthusiastic of late....
Battery life seem to fall of BIG time after 8-9 months and 3 of us in the family have noticed this and of course, the effing things are not (easily) replaceable. In fact, it's a major operation.* I run with wi-fi and BT and gps OFF during the day, to save life.
The second issue is the use of SD cards. If you set up the card to act as internal memory, the bloody thing stops recognising the card after a while. This is a relatively common software related problem across the 3 and 4 I believe from research. I had a top drawer branded card from a proper retailer die, to be followed by it's no name replacement. Now, I am just using the card for storage. The card that was not being recognised was reformatted and is happy doing service elsewhere....
* Bring back proper replaceable battery phones!!!! It's all built-in obsolesence by the bloody manufacturers. :angry:
ollydog
Has thanked: 61 times
Been thanked: 18 times
Post by ollydog »
what phone did you smash, did my i4s a few years back the only salvageable bit was the chassis ring so i got on line bought all the bits and built my own for £73 and still use it today.
if you get an older working iphone dont put any upgrades on it as it will flood the memory and seize the phone useless
steve
ollydog
Post by ollydog »
its pretty easy to change the batterys on most phones, just make sure you buy the correct batterys and not just cause its cheap, same with sd cards for gopro's
steve
SteveR
Post by SteveR »
ollydog wrote:its pretty easy to change the batterys on most phones, just make sure you buy the correct batterys and not just cause its cheap, same with sd cards for gopro's
steve
The Moto G range needs the screen removing, which entails heating the glue holding the screen in place as part of the strip down, then faffing with micro tools to access the battery. :unsure:
Agree totally about cheap SD cards, however, it can be hard to suss fakes :(
