WANTED- Adv Bike £3k Budget!
Morph
Has thanked: 211 times
Been thanked: 92 times
Re: WANTED- Adv Bike £3k Budget!
Post by Morph »
GFJ1 wrote: Wed Nov 15, 2017 6:47 pm Couple of bmw g650 xcountry up on ebay?
If I had £2,250....
https://rover.ebay.com/rover/0/0/0?mpre ... 2311075796
scoobydidler
Been thanked: 54 times
Post by scoobydidler »
Pm replied to fella.
Sent from my F8331 using Tapatalk
LadyM
Has thanked: 3 times
Post by LadyM »
Have you seen mine for sale? Really top bike!
LadyM
Post by LadyM »
GFJ1
Has thanked: 20 times
Been thanked: 50 times
Post by GFJ1 »
LadyM wrote: Wed Nov 22, 2017 7:16 pm Have you seen mine for sale? Really top bike!
That looks a nicely sorted bike at the right money. GLWS
LadyM
Post by LadyM »
To be fair you won’t find a cleaner or well
Looked after bike. Fantastic to ride and like rocking horse poop to find now. Brilliant adventure bike.
92kk k100lt 193214
Has thanked: 52 times
Been thanked: 158 times
Post by 92kk k100lt 193214 »
What's the engine configuration on the bike? If it's a boxer unusual to lose compression on both cylinders equally and either way a Hall Effect Sensor problem cannot possibly affect compression.
I am still a believer in the devil you know and happily head off to Europe on an 84 bike hitting 90k miles. Slow to change simply because you will end up with some unknowns in another bike new to you. I would always have a budget of 500 for spend on a 'new' bike no matter how good it may seem so you need to factor that in too. I have always ended up spending it, be it service, tyres, fork oil, changing out stiff cables, replacing some broken part, battery or odds and ends.
The only way I see a boxer with low compression on both cylinders is a valve timing issue and that damage is almost always top end and easy to get at. Removal of a cover somewhere may allow you to see you still have a timing chain in place...unless due to a bad tensioner it has hopped a few teeth.
On a parallel twin busted head gasket between the cylinders can also do it. The plus side of that is that doing a repair job like that can be a plus point to a buyer if you do it right and keep a record of it.
Many years back a friend always had a the idea if you got such a result to first check the measurement and the compression tester. Even more recently a fellow K owner ran a test and got some bad results. Ran it again with a mate who another tester and got results within spec.
Still think if it was mine I would fix it because its going to devalue hugely for a buyer to risk unknown damage.
Just my thought.
I was faced with a major enough job early this year on the K100RT. 78k miles at the time and I put a new clutch, rear main seal, whole back end job plus other components. Still happy with the decision to do it because all the other bits were up to date and good. As things happen another bike did come up while I was away in September and did go with it. The RT has a list of potential buyers looking for it simply because they know the usual jobs are done....but I'm not selling it.
LadyM
Post by LadyM »
Morph wrote: Wed Nov 15, 2017 11:43 pm
If I had £2,250....
Have you seen the mileage on that one? Mine looks even better value now with only just over 7k on the clock!
Return to “FOR SALE - WANTED”
