The spitfire made its maiden flight 70 yrs ago today
Mac 60
Re: The spitfire made its maiden flight 70 yrs ago today
Post by Mac 60 »
Mike101 wrote:The guns in the ME09 were not like most thought.
There were never guns in the wings as with the RAF fighters. The two 20mm cannons were in front of the pilot and fired through the prop. Eventually there were more guns mounted under pods under each wing. The ME109 wings were never thick enough tho mount guns inside.
The two 20mm cannons were far superior to the eight .303 guns in the spitfire at taking down an aircraft as they simply did more damage per hit.
If you don't beleive me go look for yourself.
Mike
illy Messerschmitt’s promising fighter finally achieved its potential with the Bf 109E variant, powered by the cutting edge DB 601A. The Emil progressed through numerous subvariants. The prototypes Bf 109V-13 through Bf 109V-20 were considered as “E-0” types.
The Bf 109E-1, delivered in early 1939, introduced a three-bladed, variable pitch propeller and twin underwing radiator intakes. It was very fast and arguably the best fighter in the world at that time. By later WWII standards, it was still lightly armed, with four rifle caliber machine guns, two in the cowling and two in the wings.
By September 1939, when Germany attacked Poland, the Luftwaffe had almost 1,000 Bf 109’s in service, mostly “E” models. 200 took part in the Polish campaign, a third of them lost, mainly to ground fire.
During the ensuing “Phony War” on the Western Front, a hapless Luftwaffe pilot set his 109E down on the wrong side of the lines. The Brits rushed the plane back to Britain for a complete evaluation; the aircraft was startlingly superior to the Hawker Hurricane under all conditions and superior to the Supermarine Spitfire at lower altitudes. Today this aircraft sits on display at the RAF Museum at Herndon.
With a top speed of 350 miles per hour at altitude, the Bf 109E-3 took good advantage of the latest Daimler Benz motor, the 1200 horsepower DB 601Aa. It incorporated a stronger canopy and more cockpit armor. It upgraded the E-1’s weaponry by replacing the wing machine guns with MG-FF 20 millimeter cannons. Interestingly, the E-3 weighed under 6,000 pounds, less than half the weight of an American P-47. (Note: the Bf 109E-2 never reached production.)
With an improved, softer recoil mechanism, the MG-FF/M cannon which appeared on the Bf 109E-4 distinguished the E-4 from the earlier E-3. The MG-FF/M could also fire highly effective explosive shells.
The “Me 109” outclassed its opponents in the blitzkrieg against France of May 1940. Needing a fighter-bomber, Jagdbomber or Jabo, the Luftwaffe fitted some Emils with bomb racks and they effectively struck Channel shipping and land targets. Jabo modifications to the 109 were denoted with a “/B” suffix, for example, Bf 109E-1/B and Bf 109E-3/B.
Battle of Britain Totally wrong about the 109 arnements. i did indeed have guns in the wings. Also in the cowl. Indeed these where later replaced by cannons. Ive copied the article here so you dont have to look for yourself. There where many versions of the ME 109 or Bf 109 whith many different weapon systems
Return to “THE PUB”
