WK400 owners thread.
Grahamkevinbutler
Re: WK400 owners thread.
Post by Grahamkevinbutler »
Andi_Archer wrote:My DRZ has the same problem I fitted some 10w 3 LED fittings to the hand guards to improve the lighting.The lighting is too wide spread but as an experiment a great improvement over the standard output.Though I had to tape the clear edges as it has a very distacting light output.
https://www.aliexpress.com/item/Motor-B ... 28999.html
That's why you need to fit the spot light version, those work well but spread the light to wide
Andi_Archer
Has thanked: 3 times
Been thanked: 126 times
Post by Andi_Archer »
I couldnt find a spot version of those, are you aware of a similar slim mount low wattage unit with less light spread?
netsonic
Has thanked: 14 times
Been thanked: 49 times
Post by netsonic »
slight change of subject and wondered if any one could do me a favor when they get 10 mins spare and remove their lower chain guide to check the black guide and hows its been installed. Whilst giving my WK a good clean on Sunday which included a chain service i tent to take easy bits apart for ease of cleaning and took the lower guide off and found the black poly guide has been cut along its lower edge to get it over the chain. The ally holder comes off whether the chain is split or not but the black guide does not and ideally needs the chain threading through before its riveted.......it does get held in place by the ally holder so no major issue just wondered if this is normal or whether our Chinese friends got the build sequence wrong on mine and the chain was already riveted in place when they found the black chain guide later :blush:
just a thought and having done a bit of inter-web looking it appears the lower guide is a KTM version and the inner guides under KTM should fit although a tad pricey. Will check with WK parts direct as this should be an item they would stock as its a service item later on
http://www.ebay.co.uk/itm/BRAND-NEW-GEN ... SwHaBWlNva
Grahamkevinbutler
Andi_Archer wrote:I couldnt find a spot version of those, are you aware of a similar slim mount low wattage unit with less light spread?
I've got something very similar in my work shop as I had the same sort of idea, what I did and you can try it, get a A4 black plastic wallet the type that you put in a filing cabinet and cut a shade to go round the lens, that works, it directs the light where you want it but in the end I went with small spots
mac10biker
Post by mac10biker »
Made a short clip of the WK in a little off road action
[video][/video]
Tyrant68
Has thanked: 56 times
Been thanked: 52 times
Post by Tyrant68 »
netsonic wrote:slight change of subject and wondered if any one could do me a favor when they get 10 mins spare and remove their lower chain guide to check the black guide and hows its been installed. Whilst giving my WK a good clean on Sunday which included a chain service i tent to take easy bits apart for ease of cleaning and took the lower guide off and found the black poly guide has been cut along its lower edge to get it over the chain. The ally holder comes off whether the chain is split or not but the black guide does not and ideally needs the chain threading through before its riveted.......it does get held in place by the ally holder so no major issue just wondered if this is normal or whether our Chinese friends got the build sequence wrong on mine and the chain was already riveted in place when they found the black chain guide later :blush:
Have found its cheaper to buy ktm chain rubber parts from ktm and not ebay.
Have a 400 exc and made the mistake thinking chain guide parts were cheaper on ebay...they weren't!
mac10biker
Try once more.....
netsonic
Post by netsonic »
Very good, looks a good place to test the bike, i plan to do a bit later in the year when its a bit dryer been a while since ive been off road on a bike so need it to be less slippy......
Richard Simpson
Post by Richard Simpson »
To be fair to KTM, some of their OE stuff is actually very reasonably priced...and some of the aftermarket stuff I've had (fork seals, for instance) were actually not just poor quality, but also the wrong size!
netsonic
Post by netsonic »
Hi Richard, i know your right......i forgot to mention im a scrooge
