just came across this post..dont know how I missed it :whistle:
On my Ta650 200kg I`ve run the front at 15psi in the mud [no change in grip from 30psi] as the tyre side walls are so hard....so now use the pirelle mt21 rallycross [excellent]
on the rear I have the k60 scout 140 profile with the centre band [cut out] as on the grass it slips like a good one...now it just grips [run at 28-18psi no real difference] again due to hard tyre wall..
Have run the rear with a puncture on hard ground and upto 25mph it was fine if a little wobbly but never came off rim
So for a big bike look for the occasional dry gravel/mud track fine but in the wet grass with center rear band [ forget it].
when I`ve used my [3] partly worn rears down I`ll be using either Mitas E09 or for radical trails the army special or even the mitas co2 but they will be fun on the raod for sure but clear the mud well on trails.
As Minky says always a compramise :cheer: these bikes arent xr400`s etc so dont kid your selfs, but a HP2 bmw on full knobblys will be brill.
Also ran the 130 profile but lasted well ...half what a 140 will do [old profile] but gripped well which is why i removed the center on the 140 profile.
