Modern bikes ??
ErikGustav2
Has thanked: 224 times
Been thanked: 988 times
Re: Modern bikes ??
Post by ErikGustav2 »
Nothing beats the 4 cylinder machines from early 80-ies
A GSX 1100 is total bullet proof. Update the charging system.
Than you can run forever.
The engine was used at drag racing with double power. Using standard bottom. No issue.
What is goos is that they where sold in mass during those days. And you can find them cheap.
But one. Spend a winter to go over it.
Possible ti di with very limited set of tools.
And than just run it for many years.
I still have one (Upgraded with big bore kit. Flats slide carbs, Öhlins shock absorbers, V&H 4 to 1 exhauset, ...
Picture of a barn find that I used as daily bike to the work for some years.
And a GS 750 after a winter up TLC.
If was used for a couple of years
Has thanked: 1612 times
Been thanked: 1830 times
Re: Modern bikes ??
A guy I used to know worked for a Yam dealer.
They had one of those big old air-cooled XJ1100/1200 whtevers in with a leaky base gasket.
It had done 100,000 miles. while it was apart he examined the bores, pistons , rings etc...all well within service limits.
The bike had been serviced regularly, good quality semi-synth oil used and had done a lot of long trips.
The engine looked like it would go on for ever, he said.
New gaskets and seals and away.
mark vb
Has thanked: 340 times
Been thanked: 714 times
Re: Modern bikes ??
Post by mark vb »
Yes, the big 4-cylinder Yams are durable, I know of some in the XJROC which are way over 100k miles, none having had any engine-related issues. I still have my XJR1300SP bought in 1999 - only 40k on the clock, but unused for the last 13 yrs.
XJR's - Oct 2011 003.jpg (202.86 KiB) Viewed 976 times
chipy
Has thanked: 39 times
Been thanked: 118 times
Re: Modern bikes ??
Post by chipy »
Mine 30 years old now and still going strong
Billy Bananahead
Has thanked: 135 times
Been thanked: 333 times
Re: Modern bikes ??
Post by Billy Bananahead »
My XS1100 given the XJR treatment. Think i've posted this before.
ImageWP_20200519_14_42_57_Pro_LI by Billy Bananahead, on Flickr
Just put this FZR1000 USD front end on my XJR1200. That engine started life as a FJ1200 which i modified to become a XJR. Not a straight swap.
ImageWP_20201030_11_10_43_Pro_LI by Billy Bananahead, on Flickr
Billy Bananahead
Re: Modern bikes ??
Billy Bananahead wrote: Sat Jan 02, 2021 9:27 pm My XS1100 given the XJR treatment. Think i've posted this before.
Just put this FZR1000 USD front end on my XJR1200. That engine started life as a FJ1200 which i modified to become a XJR. Not a straight swap. FJ exhaust system fitted too.
