That’s I was wondering if it was aluminium. I suspect so meaning I can weld it. The SM was considerably lower than the enduro, that’s why I requested the stand off it. I’ll ring them and ask them to measure the enduro standDavidS wrote: ↑Fri Mar 30, 2018 9:17 am Is the stand steel or ally? My 450 is ally so more difficult to lower although I think there is a way but 40mm would be too much because of the taper.
The 450 sits almost upright, which is fine if your parking on a beach but elsewhere it’s scary leaving it.
As standard, 5 to 10mm would be enough but the taper would be too wide for 40mm.
Husqvarna 701
Re: Husqvarna 701
Fried Egg Sandwich
- Has thanked: 180 times
- Been thanked: 65 times
Re: Husqvarna 701
I think you made the right decision after all the research you did.
Looking forward to seeing it at the Taffy
Suzuki DRZ400S
BMW R1150GS
Royal Enfield Interceptor 650
BMW R1150GS
Re: Husqvarna 701
If you're not sure how much to shorten your stand by. Why not go down this route, sure you could easily make your own up
https://www.cjdesignsllc.com/products/c ... ification/
Good bike have to bring down the plain for a play one day
Re: Husqvarna 701
Thanks mate, I look forward to seeing you on the plain. Shame the trip planned on the 10th will still be a bit early as I won’t get the bike by thezimtim wrote: ↑Fri Mar 30, 2018 12:15 pm If you're not sure how much to shorten your stand by. Why not go down this route, sure you could easily make your own up
Re: Husqvarna 701
Friends son works for Husqvarna, so I asked him.
He has replied
Hope that helps
The shorter side stand does fit, which if you are spending 8k on a new bike plus having it lowered I suggest doing it. With regards to having a set of Supermoto wheels, it does work however the cost soon limits the number of people that actually do it. You have to buy the 701 Enduro and turn it into a SM if required. It does not work the other way around.
Hope that helps
DavidS
- Has thanked: 968 times
- Been thanked: 519 times
Re: Husqvarna 701
I’ve put Mitas E07’s on the 690 but left it as original otherwise and it’s great fun on the back roads but still looks ‘off road’ like and would be fine on easier lanes. Wouldn’t fancy mud and roots or rocks though. It’s great for 50 to 100 mile or so rides, which is all I need now.
Front brake needs a boost as it’s a bit soft for proper road use but, having been sat for a couple of months now, it feels it could do with a bleed or, if not, maybe a pad upgrade.
Tonibe63
- Has thanked: 1549 times
- Been thanked: 690 times
Re: Husqvarna 701
Don't want to tell you how to suck eggs but before spending unnecessarily ......
take the pads out, push back piston, clean up the pad securing pin, copperslip the caliper sliding pins and reassemble. Put the bike on side stand, turn bars to the left so that front caliper is the highest point in the front brake circuit, pull the front brake lever in and let it flick out in quick succession to release any air.
DavidS
Re: Husqvarna 701
Brake numpty here so no eggs to be sucked.
Thanks, I’ll give it a go.
