kenny87
Re: what have you done to your the bike today??
Post by kenny87 »
Is that silicon bronze tig or oxyfuel welded?
Only recently started using it at work and wish I'd tried it years ago.
shep
Post by shep »
New set of k60's purchased, fitting next Saturday, should be fun.
Rederic
Has thanked: 72 times
Been thanked: 245 times
Post by Rederic »
kenny87 wrote:Is that silicon bronze tig or oxyfuel welded?
It was silicon bronze tig, but to be honest the filler wire was to big for the job it was starting to burn the
zinc plating off the tube
kenny87
Post by kenny87 »
Nice job though mate (thumbs)
jaffa1963
Post by jaffa1963 »
Today I installed Hagon springs in my BMW F650 Funduro. They feel really good and have given my 15 year old bike a new lease of life.
jaffa1963
Triumph Tiger 800 XCX
BMW F650
MikeC
Post by MikeC »
Rode it.... from Applecross, via Skye, Oban, Lochgilphead, Inverary, Dunoon to home near Bishop Auckland...420miles ;)
inkyjim92
Post by inkyjim92 »
Fitted some Renthal bars, Some pointy mirrors, new grips and some nice red anodized levers. I also found one of my throttle cables has snapped and looks like it has been snapped for some time so that is another thing added to the to do list :(
old ugly stuff
New decent stuff
A crossed thread is better than no thread
Brenhden
Has thanked: 1187 times
Been thanked: 734 times
Post by Brenhden »
Well, got them both out and run them for a bit as they aren't getting used :(
Then I stripped all the plastics off the KLX which made it look well cool B)
Polished them all up. Vacant space, there were some pretty deep scratches on them so I lightly sanded them down, then rubbed with a Stanley blade which got them perfect. Then on the white bits I gently sprayed some Halfords lacquer and on green bits just used WD40 which worked a lot better than the plastic polish that I spent actual money on :angry:
Finally I fixed the helmet lock which had grit in it.
All extremely satisfying.
Suzuki DR200 Djebel.
mjojom
Post by mjojom »
tapped to can bus and run feed to relay so now got powerpoint switchable with ignition for anything I want. so added auxiliary lights and USB charging point. changed screen to MRA and fabricated simple phone/gps holder. also changed bash plate from standard plastic one to mottorad aluminium. well happy with result.
vacant_space
Post by vacant_space »
Brenhden wrote:Vacant space, there were some pretty deep scratches on them so I lightly sanded them down, then rubbed with a Stanley blade which got them perfect. Then on the white bits I gently sprayed some Halfords lacquer and on green bits just used WD40 which worked a lot better than the plastic polish that I spent actual money on :angry:
Thanks Brenhden! There was me thinking that TCut / wet 'n dry may be a bit harsh - so now, that 'n WD40 it is :)
My plastics are a bit mingin' close up, and various unctions and solutions haven't really worked... Time to treat the plastic a bit more like I treat my metal (thumbs)
“Before you criticize someone, you should walk a mile in their shoes.
That way when you criticize them, you are a mile away from them and you have their shoes.”
