The best advice I was given was to spend more on a sleep mat than you spend on your sleeping bag...and to buy a decent sleeping bag.
You lose lots of body heat on cold ground and an air bed is a poor insulator. Down insulated is bliss.
If you are worried about your groundsheet on stony ground, a piece of tyvek (roofing vapor barrier) underneath the tent base works well and packs small. Free from any building site!
Sleeping mats
- Has thanked: 71 times
- Been thanked: 52 times
- Has thanked: 2282 times
Re: Sleeping mats
Yeah .. this has been an issue for me for many years, though actually I have only camped several times in that time.
I always use a footprint under the tent anyway, even if just for mud off cleaning. And does help with a legged cot thing, presumably, though they are just as cold as being on the floor, as mentioned.
I started with roll mat, and am now going back to one, having tried blow up, self inflating, etc, though never tried a down filled thing or an expensive bed mat.
I agree that the mat is as important as the bag, but bulk znd weight are important.
My thoughts are that a couple of thick wide roll mats, although bulky, can be carried high on the bike, and no need to palaver about inflating.
unfortunately, whatever i do seems to end up a real mess anyway ..
20180310_164436 by gary boy, on Flickr
- Has thanked: 305 times
- Been thanked: 135 times
Re: Sleeping mats
For camping in cold climate a piece of laminate/parket underfloor is also a good insulator under your mattress. 2mm foam with silver colour foil on one side is cheap and easily available. It rolls up small(ish). You can also get one that folds.
Tarp over your tent will help keep it warm on the inside.
Re: Sleeping mats
Exped mat. I have tried many, from a military roll up, to a airbed. I wasn't too excited about the exped when I bought it, but then the first night out
and it was so much better than all others I have tried. Had it for 3 years now, now problem. Has a built in 'pump' or use a schnozzle bag.
I have a 7 which gives an approx mattress thickness of 7 cm. Very comfy and warm.
- Has thanked: 803 times
- Been thanked: 534 times
Re: Sleeping mats
Well I have ordered the big Agnes for using on the solo trips so will see how it goes , when I'm on the outfit I can take a proper camp bed and a bigger tent ,
Re: Sleeping mats
And when my new outfit is finished I will be able to do some serious off road riding starting on the French TET , Wasp Sidecar's are fitting a Ural chassis for me at the moment , I will need some weight in the chair so should make for comfortable camping !!!
Re: Sleeping mats
Regarding down mats (and sleeping bags for that matter) don't store them in their compression sacks. Store hanging up or loose in a pillowcase.
tom
tom
