Holts Tyreweld.
- Been thanked: 5 times
Re: Holts Tyreweld.
Thanks for that. Off to get a can tomorrow, better than a long walk or a wait at the side of the road.
XT350 1988
Triumph Thunderbird 1957
Re: Holts Tyreweld.
Just picked up a can of this last week, but for car use.
After reading these posts, I think I’ll get another for the GSA
- Has thanked: 572 times
- Been thanked: 895 times
Re: Holts Tyreweld.
good to know steve ..
thats one of the reasons i wanted to go tubless to get rid of the valve ...i wernt as lucky as you mine let go big time and spat me head first down the road quite a bad fracture so that is why im trying to run sealent inside the tyre while elininating eliminate the valve base fatuge and to seal or at least slow the deflation down on puncture
...the valve was that bad no amount of sealent would have been any good ..it failed big time //scary alright
16114185_10154837935008400_2786927568431782264_n by minkyhead56, on Flickr
16196061_10154837935058400_2581502683686840007_n by minkyhead56, on Flickr
16265504_10154837934968400_4080442672439780438_n by minkyhead56, on Flickr
heres another off me klr that was not looking good ..still intact but time was ticking on that tube ...
aaaa by minkyhead56, on Flickr
good to know it will seal tubes ...the valve prob;lems are troubling ..i have since replaced the tube on every tyre change since ..as it was proper scary ...
- Has thanked: 803 times
- Been thanked: 534 times
Re: Holts Tyreweld.
It's great stuff as Steve says , I use it in my farm buggy and that gets driven through everything , a can fits neatly under the seat on the xt660 where the tools used to be , carry one in the truck , used it on my trials bike , ride on lawn mower , if the missus gets a leak she will be getting a can full
- chunky butt
- Has thanked: 54 times
- Been thanked: 699 times
Re: Holts Tyreweld.
That tyre weld gear is great , got some in the van, car, much better than the foam stuff...
- Moderator
- Has thanked: 27 times
- Been thanked: 74 times
Re: Holts Tyreweld.
Petethefeet wrote: ↑Tue Mar 27, 2018 12:52 pm I have never used this but just out of interest how easy is it to remove the Tyreweld gloop from the rim and inside of the tyre if you want to reuse the tyre. I like the idea of it but if it rights tyre off every time you use it ....
[/quote
All of these type of products are water soluble, so simply wash out the tyre to do a permanent repair.
If you're taking the wheel to a tyre fitter for repair remember to tell him it is inside, we get pissed off when we find it the hard way.
- Steve T
- Has thanked: 263 times
- Been thanked: 847 times
Re: Holts Tyreweld.
Another vote for Tyreweld.
Saw it used whilst in the middle of Galloway forest, on a punctured tube. Squirted the stuff in, rode it a little way to disperse it in the tube, put some more air into the tube, then rode it back to base camp, then all the way back home to deepest, darkest Englandshire
Always have a can of it stashed under the seat or in the tank bag. I have taken to covering the operating end in alloy tape having had a can operate in said tank bag . It might wash off of wheels, but it sure is a pain to get out of the inside of a tank bag
Steve T
Steve T
ZEN DOG
- Has thanked: 149 times
- Been thanked: 52 times
Re: Holts Tyreweld.
If you guys are having valves rip out of tubes I am guessing you haven't modded the rims at all, I always drill the rimlock and valve hole bigger and chamfer them and take off the nut at the bottom of the valvestem on anything used off road, better to let the valve twist at an angle than rip off the tube if it starts going down.
- Has thanked: 419 times
- Been thanked: 158 times
Re: Holts Tyreweld.
Strangely one of the guys I was riding with on Sunday used this for a puncture and it was shite!! leaking from the hose and it was like a white foam, is there two different types? also I unscrew the valve nut back up as far as the dust cap to allow for valve movement
- WIBO
- Has thanked: 612 times
- Been thanked: 650 times
Re: Holts Tyreweld.
That's what I do...I've had the odd flat with an angled valve stem but not torn off.
On my XT where there's no rim locks but a tight bead ...it's important that there's some movement at least.
Will It Buff Out?
