Novice mistake
- Been thanked: 99 times
Novice mistake
Made a novice mistake the other day, was on the Livingston dual carrigeway which js 50 MPH.
Was riding behind a guy in a sports car who was doing 40 MPH which I thought was rather slow, so I pulled out to overtake and as I was passing we came around a bend in the road to reveal a speed camera, was on my CBF1000 which has dials, seemed to indicate about 50 MPH on the speedo.
But a bit touch and go, after all it is not good practice to look at the speedo when you are overtaking someone.
We find ourselves riding bikes that do not actually tell us what actual speed we are doing, it would have been fine on the Super Ten which I have loaded with high Tech aand could have looked up the actual speed.
Re: Novice mistake
I suppose the way around this problem would be to have look ahead capability.
You could run a drone locked to the bike , sounds hi tech, but certainly doable these days, it could identify hazards ahead of the bike, obviously to provide audidable warning (to avoid visual distraction)s, but not something that you want to get into, as it could be a short step into something more sinister.
Re: Novice mistake
Any Sat Nav will show your speed ... better than a built in speedometer
Or am I missing something (VERY basic) here ?? !!
If a Hammer don't fix it - you have an electrical problem
- Has thanked: 3467 times
- Been thanked: 1823 times
Re: Novice mistake
Now you know where the camera is get a can of yellow spray paint ................allez les gilets jaunes
I'M HERE FOR A GOOD TIME NOT A LONG TIME
https://www.facebook.com/groups/1806825 ... =bookmarks
https://www.youtube.com/user/PHILinFRANCE1
- Has thanked: 2280 times
- Been thanked: 992 times
Re: Novice mistake
My understanding is that all vehicles in the UK have speedos calibrated to read 10 mph over actual speed , so showing 50 is actually 40 mph?
Sat navs, I believe, show actual speed.
Also police guidance is to alow a rider or driver 10% plus 1 or maybe 2 mph over? but is discretionary only.
So possibly ok to do 56 mph actual speed .. or is that 66mph indicated?
Best try it out, and let us know
- Has thanked: 1177 times
- Been thanked: 727 times
Re: Novice mistake
Agreed, my checks have come back at about 10% on my ragged collection of suzuki dual sports...
- Snaf MKII
- Has thanked: 923 times
- Been thanked: 753 times
Re: Novice mistake
Speedo can have a tolerance of +10% + (I think) 10kmh so Gary is right in 40mph might read 50mph but it can be anything between the two. What it must not be is lower or higher than that.
I expect that we've all seen lag in GPS speed in poor weather, tree coverage, canyons and mountain riding. What I've never seen is a GPS reading higher than the speedo.
My new Transit connect reads about 2% higher than the GPS at steady motorway speeds.
