Checked the chain and slackened a little more aswell just incase my weight was the issue causing it to be a little tight underload but still the same ... the sparkles and farkles i did my self the bike orignally cone to me like this
- FB_IMG_1599166540734.jpg (82.5 KiB) Viewed 2396 times
The tires are same i did use some different rim locks though once replacing the tires qnd changed the exhaust from standard to a yoshimura rs4 ... will ask previous owner if he had issues with this on has he took it off saying it was to load ... iam leaning towards feuling maybe now and the exhaust as when i pull the clutch in and free roll qt the same speed it isnt there its only when at 4500-5000rpm in 4th and 5th gear ... other than that everything is fine ...
