Clutch help
Re: Clutch help
I have just used the old 1p trick on the Pampera. Take care not to over tighten the clutch clamping bolts, they are prone to snap in the clutch basket fingers. When securing them tighten a little and often alternating diagonal pattern.
It is possible to buy a pattern product of the Honda factory clutch tools and for what they cost they could be an investment to you, as an example;
https://www.motorcycleproducts.co.uk/mo ... ls/3/34354
Ps my penny, apologies 'Mam.
- Has thanked: 165 times
- Been thanked: 159 times
Re: Clutch help
In my experience a significant amount of clutch issues are caused by the cable. Anything apart from a fresh OEM cable will not work properly, the usual problem of not being able to select neutral easily as the clutch is not releasing correctly. And/or less than smooth operation.
Not sure if this is the fault cause here, but always consider the cable if grabbing your clutch does not result in the satisfaction you hope for!
- Steve
Southampton area
DR350, 349, DRZ, 701
Southampton area
- Snaf MKII
- Has thanked: 921 times
- Been thanked: 752 times
Re: Clutch help
The trialists use a clutch lightner on thier TLR Hondas which have the same base engine and clutch mechanism.
https://www.ebay.co.uk/itm/HONDA-tlr200 ... 0877802951
- Has thanked: 1177 times
- Been thanked: 727 times
Re: Clutch help
Will swap out the cable, at least thats easy and cheap, this bike has the easiest to find neutral I've ever owned.Thedktor wrote: βTue Jul 14, 2020 6:22 am In my experience a significant amount of clutch issues are caused by the cable. Anything apart from a fresh OEM cable will not work properly, the usual problem of not being able to select neutral easily as the clutch is not releasing correctly. And/or less than smooth operation.
Cool widget, but the clutch is light.Snaf MKII wrote: βTue Jul 14, 2020 7:08 am The trialists use a clutch lightner on thier TLR Hondas which have the same base engine and clutch mechanism.
Re: Clutch help
I have one of those, there is no way to get in there without itHugh wrote: βMon Jul 13, 2020 8:31 pm Greetings,
- Been thanked: 5 times
Re: Clutch help
I was convinced the clutch on the XT was on the way out last year, looked at clutch kits etc.
Took the cable off at both ends and when you pulled the cable inner through it was like it was lubricated with treacle, would move freely but very damped, think it was were it ran past the exhaust and the oil had dried out and got thicker over the years.
I new cable sorted it, different world.
Hope it helps
Pete
Hope it helps
Pete
XT350 1988
Triumph Thunderbird 1957
Re: Clutch help
Here is my one, annoyingly back first...
- Clutch.JPG (31.24 KiB) Viewed 1991 times
