Audible plug warning doofer
If you know how to do something, share it with other members. i.e How to fix a puncture...How to ship a bike to Alaska etc. The post with the most 'Thank You' votes in a month wins an ABR Hoodie.
daveuprite
Has thanked: 2452 times
Been thanked: 3293 times
Re: Audible plug warning doofer
Post by daveuprite »
Thanks Bill - some good ideas there.
SteveW
Has thanked: 265 times
Been thanked: 264 times
Post by SteveW »
I use a couple of pumps with float/tilt switches in sumps for my land drainage.
Not the same usage as your situation.
I'm just thinking laterally....you could fit a header tank, use your pump to fill that, then use gravity to distribute the water from the header to where you want it, you could fit a tap/stop clock to the end of the hose/pipe.
You'd have to hang about whilst the header tank fills, but if the header is big enough, it could be more efficient.
daveuprite
SteveW wrote: Sat Feb 01, 2020 7:37 pm I use a couple of pumps with float/tilt switches in sumps for my land drainage.
Thanks Steve - problem is... I'm pumping from 9 metres deep, of which sometimes as much as 8 metres is full of water (like right now after all the rain we've had). And then it must pump out 75 metres at ground level via hose to the large bins we place in the paddocks for the geegees. That's why I'm using an 1100 watt, 6000 litre/hr Flotec Sub8 pump (cost over 400 euros). I don't think a header tank wouldn't give me the pressure (unless I mounted it on a bloody tower or something). At present I can fill 10 x 90 litre bins in about 15 minutes, even 75 metres away from the well down an 18mm hose - which is pretty good.
We also use the well as a rainwater storage tank for water gathered by the gutters on our barn - so it gets topped up with every shower. The system is working well actually and I'm happy with my set up - if only I could remember to turn the f*cker off... :)
qcnr
Has thanked: 695 times
Been thanked: 243 times
Post by qcnr »
Set a timer on your phone when you switch it on... ;)
And put a notice up saying set timer before switching on.... :D
daveuprite
qcnr wrote: Sun Feb 02, 2020 8:31 am Set a timer on your phone when you switch it on... ;)
Yeah, but how will I remember to look at the notice...?
DavidS
Has thanked: 830 times
Been thanked: 417 times
Post by DavidS »
Cheaper still, a big note on the fridge saying HAVE YOU TURNED THE ****** PUMP OFF?
2023 Husqvarna Norden 901
2014 KTM 690 ENDURO R
Oop North John
Has thanked: 154 times
Been thanked: 199 times
Post by Oop North John »
daveuprite wrote: Sun Feb 02, 2020 8:39 am
Put a reminder on the phone?
bill_qaz
Has thanked: 689 times
Been thanked: 898 times
Post by bill_qaz »
Mains cable from pump to left testicle bet you don't forget to switch it off now :lol: :idea: ñ
daveuprite
Oop North John wrote: Sun Feb 02, 2020 6:08 pm
Dear Liza, dear Liza.....
Has thanked: 2280 times
Been thanked: 992 times
Post by garyboy »
start the pump
remember to always set the alarm on your mobile phone at this point, as a routine
(allow enough time for the pump use)
keep phone with you at all times (most of us do)
(wrap phone in plastic bag if raining, place in close pocket)
jump like f*ck when the alarm goes off
try to remember why you set the alarm
:lol:
Return to “HOW TO..........”
