R1200GS frame to engine bolts
Ian S
Post by Ian S »
hi, i have just fitted some givi engine bars to my 2004 GS, they fit to the lower engine frame mount at the bottom of the engine, anyone any idea on torques ?? they are T55 headed and about 4 1/2" long.
SSchultz
Re: R1200GS frame to engine bolts
Post by SSchultz »
Give me your email address on PM, got a pdf service manual if you want it.
Britmech
Post by Britmech »
The ones below cylinders ? are 55nm (originally the size would have been M12 x 50 before bars fitted)
AndyB
Post by AndyB »
Ian S wrote:hi, i have just fitted some givi engine bars to my 2004 GS, they fit to the lower engine frame mount at the bottom of the engine, anyone any idea on torques ?? they are T55 headed and about 4 1/2" long.
Can of worms time...
The torque settings will change if you intend using anti seize paste or fitting them dry. I'd just go for a couple of grunts and be done with it :whistle:
Being serious though; the head size is totally irrelevant, what you need to be looking up is the thread size, the grade of bolt and the material you're nailing it into. Everything is out there if you use Google but the head and length of bolt don't count.
Ian S
Post by Ian S »
found 3 different torques, 55nm, 72nm & 110nm, so mean average it is !!
thanks fellas
