How "NOT" to Husky
If you know how to do something, share it with other members. i.e How to fix a puncture...How to ship a bike to Alaska etc. The post with the most 'Thank You' votes in a month wins an ABR Hoodie.
HU55KY
How "NOT" to Husky
Post by HU55KY »
Something ate my Husky!
It's a 2005 te 510 and it's got a big hole where it shouldn't have...
So I've downloaded the manual and started taking it all to bits with no previous experience beyond checking the tyre pressures and lubing a chain!
Got the plastics and tank off, battery out, exhaust off, carb off and there are scorched marks through two of the hoses...
Clutch hose disconnected, wiring loom un plugged, chain off and soaking, frame guards off and... where's the 22mm rear swingarm axle nut gone???
And why didn't the manual tell me to detach the rear shock before I tried to pull the swingarm off?
Don't tell me... it got lost in the translation! :unsure:
Simon_100
Has thanked: 44 times
Been thanked: 112 times
Re: How "NOT" to Husky
Post by Simon_100 »
Blimey, look at that gearbox sprocket - someone has really gone to work on that bike, mega zero maintenance!
Good luck matey (thumbs)
Simon
Redmurty
Has thanked: 337 times
Been thanked: 153 times
Post by Redmurty »
Looks painful, good luck
cheers Spud ;)
Richard Simpson
Post by Richard Simpson »
"Don't worry sir, they all do that!"
Seriously, good luck with it.
You will find the advice given on here (and it will be given, whether you ask or not) will be of varying quality.
However the Thedktor has rebuilt a husky 4-stroke and documented it all on this forum...so if he offers you advice, take it! He's about the best of the 'forum mechanics' that I know.
HU55KY
Post by HU55KY »
Very good of you, thank you!
Mad Hatter
Been thanked: 96 times
Post by Mad Hatter »
'kin hell dude what happened there :ohmy:
That's more or less what I did when one of mine went bang and I'm glad I did fix it I learnt a lot and I'm sure you will as well.
Have fun :laugh: Hope it goes smoothly dude (thumbs)
mechanic
Has thanked: 13 times
Been thanked: 46 times
Post by mechanic »
Try the cafe husky forum over in the states, it's a wealth of husky info written by some very informed people. Nige
daytona-supersport
Post by daytona-supersport »
Are you sure that's not a cooling feature for the crank?
At least there was not a load of metal bits whizzing round inside the crank case.
Did you collect up all the pieces. It may be possible to weld up.
No worries. A bit of ally plate and plastic metal and she will be right a rain.
This sort of thing happens when you wash a Husky.
The swinging arm did not drop off so why bother with the nut?
Crispy pipes. No biggy until they warm up properly and set the carb alight.
You have only had the bike two days and already broken it.
There are easier ways to change the oil.
That's clever, a crank inspection port.
Good thing it's only a small hole.
Run out of pish takes for now.
Not good matey. I fink the motor is stuffed. Maybe get some cash back for the rest of the bike. Do not buy another of the same.
mjojom
Post by mjojom »
is that a rust in between tooth on crank?
johnnyboxer
Has thanked: 100 times
Been thanked: 523 times
How "NOT" to Husky
Post by johnnyboxer »
That is Italian Husky for you :)
We buy things we don't need
With money we don't have
Return to “HOW TO..........”
