Montana help
GB
Been thanked: 9 times
Montana help
Post by GB » Wed Feb 08, 2017 7:27 pm
Went to use my montana on the powered rugged mount today and it wasnt charging it, checked the connections and fuses etc all ok, is there a way of testing which connector does what on the holder or even the unit itself, dont want to buy a new holder and its the unit or visa versa?
Finally back on a GS :D
Kipper
Re: Montana help
Post by Kipper » Wed Feb 08, 2017 7:53 pm
Don't know how to check but I have had issues with pins in cradle. Either stuck in or broke.
Also recently had a flat bike battery which meant there wasn't enough charge to power the Montana.
qwerty
Has thanked: 19 times
Been thanked: 44 times
Re: Montana help
Post by qwerty » Wed Feb 08, 2017 7:55 pm
Hi GB these are the power pins on the rugged mount, one of the connecting spades to my ktm wiring vibed loose in morocco last oct, so I would check there.
GB
Re: Montana help
Post by GB » Wed Feb 08, 2017 7:56 pm
Im hoping its the cradle not the unit, it is one of the first ones and has had a hard life.
GB
Re: Montana help
Post by GB » Wed Feb 08, 2017 7:58 pm
qwerty wrote:Hi GB these are the power pins on the rugged mount, one of the connecting spades to my ktm wiring vibed loose in morocco last oct, so I would check there.
Thanks mate, will do.
qwerty
Re: Montana help
Post by qwerty » Wed Feb 08, 2017 8:31 pm
Sorry, I meant to add you should get 14v with the bike running. I also wired mine into the Non-permanent (don't know if its the same on a 701)
AustinW
Has thanked: 4 times
Been thanked: 12 times
Re: Montana help
Post by AustinW » Wed Feb 08, 2017 8:43 pm
I had this issue with mine a year or two back. I thought it was the mount, it wasn't it was the Montana but Garmin took a lot of persuading of that. If I put a bit of flex pressure on the Montana it would mount and charge but the slightest knock or vibration and it stopped being powered from the mount. To my mind clearly a fault in something like the PCB or a soldered joint somewhere. Garmin replaced it as it was still under guarantee (it was already a replacement).
Oh, and check the battery is fitted OK.
GB
Re: Montana help
Post by GB » Wed Feb 08, 2017 9:46 pm
AustinW wrote:I had this issue with mine a year or two back. I thought it was the mount, it wasn't it was the Montana but Garmin took a lot of persuading of that. If I put a bit of flex pressure on the Montana it would mount and charge but the slightest knock or vibration and it stopped being powered from the mount. To my mind clearly a fault in something like the PCB or a soldered joint somewhere. Garmin replaced it as it was still under guarantee (it was already a replacement).
I have no battery fitted, but they are the symptoms mine is showing, I will test the cradle tomorrow but the unit is way out of warranty if it is that.
WIBO
Has thanked: 562 times
Been thanked: 628 times
Re: Montana help
Post by WIBO » Thu Feb 09, 2017 7:58 am
Normal for Roger...as a kid,he broke all his toys on Xmas morning and had nothing to play with in the afternoon. :laugh: :laugh: :laugh: :laugh:
Will It Buff Out?
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a f**k what you think.
qwerty
Re: Montana help
Post by qwerty » Thu Feb 09, 2017 8:32 am
Morning Mr Boyd, you checked your email recently?? :whistle:
Users browsing this forum: No registered users and 14 guests
