Audible plug warning doofer
daveuprite
Has thanked: 1559 times
Been thanked: 2041 times
Re: Audible plug warning doofer
Post by daveuprite » Sat Feb 01, 2020 7:21 pm
Thanks Bill - some good ideas there.
SteveW
Has thanked: 265 times
Been thanked: 261 times
Post by SteveW » Sat Feb 01, 2020 7:37 pm
I use a couple of pumps with float/tilt switches in sumps for my land drainage.
Not the same usage as your situation.
I'm just thinking laterally....you could fit a header tank, use your pump to fill that, then use gravity to distribute the water from the header to where you want it, you could fit a tap/stop clock to the end of the hose/pipe.
You'd have to hang about whilst the header tank fills, but if the header is big enough, it could be more efficient.
daveuprite
Post by daveuprite » Sat Feb 01, 2020 9:40 pm
Thanks Steve - problem is... I'm pumping from 9 metres deep, of which sometimes as much as 8 metres is full of water (like right now after all the rain we've had). And then it must pump out 75 metres at ground level via hose to the large bins we place in the paddocks for the geegees. That's why I'm using an 1100 watt, 6000 litre/hr Flotec Sub8 pump (cost over 400 euros). I don't think a header tank wouldn't give me the pressure (unless I mounted it on a bloody tower or something). At present I can fill 10 x 90 litre bins in about 15 minutes, even 75 metres away from the well down an 18mm hose - which is pretty good.
We also use the well as a rainwater storage tank for water gathered by the gutters on our barn - so it gets topped up with every shower. The system is working well actually and I'm happy with my set up - if only I could remember to turn the f*cker off... :)
qcnr
Has thanked: 355 times
Been thanked: 176 times
Post by qcnr » Sun Feb 02, 2020 8:31 am
Set a timer on your phone when you switch it on... ;)
And put a notice up saying set timer before switching on.... :D
daveuprite
Post by daveuprite » Sun Feb 02, 2020 8:39 am
Yeah, but how will I remember to look at the notice...?
DavidS
Has thanked: 740 times
Been thanked: 344 times
Post by DavidS » Sun Feb 02, 2020 2:06 pm
Cheaper still, a big note on the fridge saying HAVE YOU TURNED THE ****** PUMP OFF?
2019 Triumph T120 Black and 2015 Husky FE450
Oop North John
Has thanked: 87 times
Been thanked: 129 times
Post by Oop North John » Sun Feb 02, 2020 6:08 pm
Put a reminder on the phone?
bill_qaz
Has thanked: 340 times
Been thanked: 550 times
Post by bill_qaz » Sun Feb 02, 2020 6:19 pm
Mains cable from pump to left testicle bet you don't forget to switch it off now :lol: :idea: ñ
daveuprite
Post by daveuprite » Sun Feb 02, 2020 7:28 pm
Dear Liza, dear Liza.....
garyboy
Has thanked: 1323 times
Been thanked: 567 times
Post by garyboy » Sun Feb 02, 2020 8:01 pm
start the pump
remember to always set the alarm on your mobile phone at this point, as a routine
(allow enough time for the pump use)
keep phone with you at all times (most of us do)
(wrap phone in plastic bag if raining, place in close pocket)
jump like f*ck when the alarm goes off
try to remember why you set the alarm
:lol:
Return to “HOW TO..........”
Users browsing this forum: No registered users and 5 guests
