Ah Spud I to have a smirk on my face, you need to ride faster!Redmurty wrote:I read this thread with a little smirk on my face and think I must be a shite rider, I can't feel any vibration or wheel being out of balance when I'm on nobblies
I admire you guys who can do that (thumbs)
cheers Spud
polymorph and rim clamp balancing
- Has thanked: 105 times
- Been thanked: 153 times
Re: polymorph and rim clamp balancing
You'd really notice the difference on tarmac, even if you only get them balanced "somewhere near right" Much less vibey and wobbly.Redmurty wrote:I read this thread with a little smirk on my face and think I must be a shite rider, I can't feel any vibration or wheel being out of balance when I'm on nobblies
cheers Spud
If you use the thin sticky weights and put two rows or whats needed, stick them to the rim under the rim tape. I never leave the rim tape in there any way but use masking tape. So clean the rim stick um on and then wrap tape around the complete rim sealing it and securing the weights. I could show you but I aint taking tyres off just so you can see. It works a treat. Ah I have an enduro wheel with no tyre on if your still not sure whats going on?minkyhead wrote:you mean under the rimtape ?that may work but ill need a much lighter rimlock ithink ..the weights on the rear were silly big ..i kept thinking this cant be right ..but the balencer told me it was and so it proved after fittingcaptinktm wrote:Balance the wheel and rim lock and put the weights on the inside! Easy. Your rear shock may be on it's last legs if that's where it's most noticeable.minkyhead wrote:all good advice ..ive used them alot beore bur for some reson this time they were realy bad ..i couldnt find a spot on the tyre to work with and ive never found any weights to fit the rim properly thus the weird solution
those lead ones seem to be good ..anyone know where i can get some narrow ones circa 5ml ?
it only showed at speed of 60 ..70 was annoying and 80 was terrible
it was the rear wheel causing the most problem i did that first and most of the vibs were gone ..the front wasnt nearly as bad in isolation
the motion pro ones are 40 percent lighter ill get some next time to reduce the amount of weights needed
the rear shock is perfect but with that amount of inbalence id guess it wont do the shock much good long term
- Has thanked: 570 times
- Been thanked: 894 times
..off road spud i wouldnt notice anything with the bounce surfaces and lower speed and for some reason this time it was annoyingly bad much worse than before and ive used the same clamp before ?started around 60 annoying at 70 and feckin awful 80and aboveRedmurty wrote:I read this thread with a little smirk on my face and think I must be a shite rider, I can't feel any vibration or wheel being out of balance when I'm on nobblies
cheers Spud
with the high ratio box the bike will cruise at 75/80mph all day and a different rider on a differnt bike on a closed road ..not me as a one off . has had it south of 105mph true ..id say under 70 i could live with it but at motorway cruising speed it was just too much
- Has thanked: 337 times
you're not wrong there mate, but I'm trying :pinch: honest (thumbs)captinktm wrote:Ah Spud I to have a smirk on my face, you need to ride faster!Redmurty wrote:I read this thread with a little smirk on my face and think I must be a shite rider, I can't feel any vibration or wheel being out of balance when I'm on nobblies
cheers Spud
cheers Spud
got it ..i think next time ill get a motion pro clamp and balence it the way you said nice clean solution thankscaptinktm wrote:If you use the thin sticky weights and put two rows or whats needed, stick them to the rim under the rim tape. I never leave the rim tape in there any way but use masking tape. So clean the rim stick um on and then wrap tape around the complete rim sealing it and securing the weights. I could show you but I aint taking tyres off just so you can see. It works a treat. Ah I have an enduro wheel with no tyre on if your still not sure whats going on?minkyhead wrote:you mean under the rimtape ?that may work but ill need a much lighter rimlock ithink ..the weights on the rear were silly big ..i kept thinking this cant be right ..but the balencer told me it was and so it proved after fittingcaptinktm wrote:Balance the wheel and rim lock and put the weights on the inside! Easy. Your rear shock may be on it's last legs if that's where it's most noticeable.minkyhead wrote:all good advice ..ive used them alot beore bur for some reson this time they were realy bad ..i couldnt find a spot on the tyre to work with and ive never found any weights to fit the rim properly thus the weird solution
i thank everyone for their input but i do like captain ktms idea the best so far
- Has thanked: 2280 times
- Been thanked: 126 times
Im sure I saw an image of a spoke mounted counterweight recently
- Been thanked: 1 time
I've used plumbers solder wrapped around the spokes to balance mine.
The lead weights will fit nicely if you can put a bend in them to follow the shape of the rim.
Flatter lead weights available for Karting off ebay
